[VIDEO/PICTURES] KZ 650 - Electrical Start Problem
- zell
Re: [VIDEO/PICTURES] KZ 650 - Electrical Start Problem
14 May 2017 07:32
Hi Guys,
Finally got time to post here
SWest - Got ya. I think the stator is working fine. At video below you can see the test I did to check the stator.
650ed - Thanks for the link. So should I consider the test I did on the wires as it is working fine?
If the stator and wires from it are working, what would be than? reg/rectifier?
Thanks again for all your support gents
1980 Kawasaki KZ 650 - F1 model
14 May 2017 08:08
I believe you will find the manual has test procedures for the rectifier/regulator. I would run those tests to see if they reveal a problem. The charging system on my 1977 KZ650 is quite different than the one on your newer bike, but in my case the test procedures clearly indicated a bad rectifier. I replaced it and the charging system starting working perfectly. Ed
