Intermittent Starting Problem
  • Rave71
  • Rave71's Avatar Topic Author
Re: Intermittent Starting Problem
29 Feb 2016 19:13
#713142
So I've repaired the broken yellow and black wire and another blue and white I found with a crack in it:
Attachment image-2-3-4-5-6-7-8-9-10-11-12-13-14-15.jpeg not found
Only problem is this has not fixed my problem. I further investigated the harness and don't see any other visible damage. I'm at a loss now. Any point to point checks I can make? Any suggestions?
1981 Kz750 ltd
Hudson Valley NY
USMC/OIF Vet
  • Rave71
29 Feb 2016 22:13
#713156
Well I finally got too frustrated, assumed the worst and pulled the tank off... Cut all the looming and tape from the harness and started tracing wires for breaks or shorts. Low and behold I find this freaking ground plug, completly separate from the entire rest of the harness, half pulled out of the connected, a quick push back together and I was back in action. Took me another two hours to re-wrap the harness in loom and tape it up. Also a giant PITA to get all those connectors and wires stuffed back into the headlight but it's all together and I'm back in action.
Attachment image-2-3-4-5-6-7-8-9-10-11-12-13-14-15-16.jpeg not found
1981 Kz750 ltd
Hudson Valley NY
USMC/OIF Vet
  • SWest
  • SWest's Avatar
  • 10 22 2014
01 Mar 2016 07:11
#713200
Yeah, it's usually something stupid. :dry:
  • jdvorchak
  • jdvorchak's Avatar
02 Mar 2016 06:43
#713403
Good job finding the problem and averting more potential problems.
Don't fix it until it's broken.
John
83 KZ550M1
83 KZ1100LTD
Also own:
2010 Harley Ultra Classic Limited, 2008 Harley low rider 71 CB350/sidecar
  • Zephyrrider
  • Zephyrrider's Avatar
03 Mar 2016 12:40
#713639
Good one mate ;)
Mick
1994 ZR750 Zephyr C4.
