weak spark
- oreis
Re: weak spark
10 Sep 2015 15:48
If you have a bad ground from the battery to the engine, the points won't work right. You'll also fry the ground in the harness.
- Randombeat
- 0 to 100 real quick...
Re: weak spark
10 Sep 2015 16:22
neutral safety switch, clutch in? simple stuff gets me all the time.... spent an entire weekend cleaning my electric, only to find a kink in the fuel line....
glad i cleaned it all, but i was pissed!!!!
1980 KZ750H LTD-- pods-- vance & hines 4-1 --speedo/tach/blinker/switch deletes -- brat style
- oreis
Re: weak spark
13 Sep 2015 17:20
Steve oh yea i found that out real well bought it from a guy who was restoring it had wires in the wrong place.. had the main battery ground to a rubber grommet that helps hold the battery box. I'm changing the coil since i don't know where else to go it should be here in a few days.
- oreis
Re: weak spark
13 Sep 2015 17:21
mine doesn't have a neutral safety it cranks fine just no spark I'm going tot how a coil at it and see all the wires check out ok.
Randombeat wrote: neutral safety switch, clutch in? simple stuff gets me all the time.... spent an entire weekend cleaning my electric, only to find a kink in the fuel line....
- oreis
Re: weak spark
15 Sep 2015 15:39
so i replaced the coil and it starts and runs great. i just can't get it off idea with the choke off. with the choke on i can rev it up just fine. so i sprayed a little starter fluid in the carb and it dies.
