1981 CSR650 Keycode
- xxsierraxx
Just picked up a nice little '81 CSR650. I got papers for it but unfortunately there is no key. I have read you can get the code off the ignition but I have removed the whole mechanism and cannot see a key code. On that year bike, where else might I look?
Thanks
1979 KZ1000
1981 CSR 650
Honda "cough"
- Thank you received: 1656
After determining the code, one source for replacement keys is eebbaayy: try searching the key number --- I did the other day & found a seller who cuts new keys using the code you provide.
2 Kawasaki Motorcycle Keys Code Cut Z5601 thru Z5650
- Thank you received: 2829
- Thank you received: 2098
www.kzrider.com/forum/4-electrical/41487...y-by-the-code-number
- xxsierraxx
1979 KZ1000
1981 CSR 650
Honda "cough"
Did you try cleaning the switch where the code is supposed to be? (the code in the pic is upside down)
The seat lock & helmet lock are your other options, but the seat needs to be open to remove them. pretty sure.
- xxsierraxx
1979 KZ1000
1981 CSR 650
Honda "cough"
- xxsierraxx
1979 KZ1000
1981 CSR 650
Honda "cough"
- xxsierraxx
1979 KZ1000
1981 CSR 650
Honda "cough"
xxsierraxx wrote: Actually, after a little more cleaning and searching I found the code Z5683. From what I've read that's the number I'm looking for. Any recommendations on someone in Canada or US who cuts keys for these?
KZr member rstnick
See my earlier post.
