Can someone verify the correct amp coils for a 77
  • ezrider714
  • ezrider714's Avatar Topic Author
07 May 2015 19:35
#671085
650C..... My FSM for 77's has become MIA :dry: . Looking to purchase DynaCoils not sure of what amp output this bike takes. my 78 650SR's use the green 3.0 amps....Does the 77 's use the same??? Any help appreciated...... ;)
EZ
78 KZ650SR Mine since 79
4-1 Mac Jet Hot coated since mid 80's
Dyna Coils
Saddlebags (I ain't skeered of going nowhere) :)
  • missionkz
  • missionkz's Avatar
Re: Can someone verify the correct amp coils for a 77
07 May 2015 21:08
#671089
Ohms, ohms ohms...... if points I bet 3 to 4 ohms is it,
Bruce
1977 KZ1000A1
2016 Triumph T120 Bonneville
  • TexasKZ
  • TexasKZ's Avatar
  • Away
08 May 2015 05:30
#671100
Probably 3. Why not give Z1E a call?
  • TexasKZ
  • TexasKZ's Avatar
  • Away
08 May 2015 05:37
#671101
The following user(s) said Thank You: ezrider714
  • TexasKZ
  • TexasKZ's Avatar
  • Away
08 May 2015 05:42
#671102
  • TexasKZ
  • TexasKZ's Avatar
  • Away
08 May 2015 05:43
#671103
Surprising what a minute or two with the search box will turn up, eh?
  • loudhvx
  • loudhvx's Avatar
08 May 2015 09:38
#671126
Factory points coils were almost always 4 ohms. If you have a Dyna S ignition, you can go down to 3 ohms.
You can also use 3 ohms with points, but it will shorten the life of the points a bit since there will be more current.
  • ezrider714
08 May 2015 17:38
#671180
Yes ohms ohms ohms.....brain freeze :blink: from spending over an half hour with the search box and finding nothing, I find the search here the worst of any kind of site I use :ohmy: With ignition more current always make me smile :cheer: No phone access at this time just Internet....Spent all of today working on trucks :blush:
Thanks for all the input, I will verify with Z1 before placing the order :ohmy: I always like to sound like I know what I'm taking about...when asking about parts..... Even Z1 is nor perfect, but they strive to be and will make things right ;)
Dyna Coils
  • ezrider714
08 May 2015 17:47
#671182
Thanks this post was a good read...... I couldn't find it :(
Dyna Coils
  • loudhvx
  • loudhvx's Avatar
09 May 2015 07:15
#671239
If you are running points, these are your options:
In my opinion, this is your best option, but they are always out of stock:
www.z1enterprises.com/ItemDetails.aspx?i...zuki&item=EM24-72451
This is the Dyna 5.0 ohms.
www.z1enterprises.com/ItemDetails.aspx?i...DC10-1&item=DYDC10-1
This option will work, but will slightly lower point life.
Dyna 3.0 ohms.
www.z1enterprises.com/ItemDetails.aspx?i...9+DC1-1&item=DYDC1-1
  • missionkz
09 May 2015 11:14
#671251
As mentioned in earlier threads about this.... I am running two 3 ohm Dyna coils with points, temporarily right now, but, I also fabricated a ballast resistor from two, 4 ohm 50 watt Arcol resistors, wired in parallel for a measured 1.9 ohms.
Bruce
1977 KZ1000A1
  • ezrider714
09 May 2015 22:06
#671316
Have stock point set-up.....
The link to the 3.0 Green DynaTek's is what I use on 2 1978 650SR's and I have had no problems...To me points are expendable just like plugs and if if shortened the life it's not enough to even notice
Thanks Loudhvx
Just checking that 1977's weren't some oddball set-up :ohmy:
Thanks to all
EZ :)
Dyna Coils
