How to Test 1980 KZ1000G Classic Computer ECU
  • Z Parts
  • Z Parts's Avatar Topic Author
07 Oct 2014 10:25
#649965
Need to know if there is anyway to test the ECU computer off the bike if it is good or not. Any help would be appreciated.
  • loudhvx
  • loudhvx's Avatar
Re: How to Test 1980 KZ1000G Classic Computer ECU
07 Oct 2014 11:05
#649969
Not simply with a meter.
You can bench test it with a good coil and a battery and some wire. I can give details if needed.
I will eventually draw up a test diagram for bench testing for actual spark.
This link shows how to make one from HEI parts.
home.comcast.net/~loudgpz/GPZweb/Ignition/GPZgmHEImod.html
The following user(s) said Thank You: Z Parts, th00r
  • th00r
  • th00r's Avatar
15 Oct 2014 13:52
#650737
instant bookmark of loudhvx link ! thanks
yet... thats for the igniter... i believe Z Parts is trying to test the computer under the seat. For the G classic i think will be kind of impossible unless you can get the signals from all the EFI sensors.
in the past I have found some jonke owners and G classic owners that said they tested the computer by plugging it to a fullyworking bike but i cant belive that because:
1) never seen together 2 of the few EFI working in the world
2) I would never let any one put anything in my classic (that sounds odd)
3) i would never lend my working ECU
Current:
2013 BMW F800gs
2012 HD Seventy Two 1200cc
1980 KZ1000 G1 1000cc
Sold but still loving:
2009 Vento Avia 125cc
2008 Vento Thunder 300cc
2005 Vento Rebelian 150cc
  • Tyler
  • Tyler's Avatar
15 Oct 2014 20:36
#650776
do the basics as if it were a car, test it on your bike. it's it a no spark, no fuel, our none of either?
do you have power? proper ground? at the ecu.
"74 Yamaha DT 400 Enduro
  • loudhvx
  • loudhvx's Avatar
15 Oct 2014 21:50
#650783
Oops, sorry, didn't realize he meant the computer for EFI. :blush:
  • steell
  • steell's Avatar
19 Oct 2014 09:07
#651121
Maybe put noid lights on your injectors to see if they are getting a signal?
  • farmer1
  • farmer1's Avatar
20 Oct 2014 00:14
#651206
Yes they can be tested. I sent me ECU to ..Bettabikes.. in Adelade.. Australia. They fixed it and sent it back. When I pluged it in the bike fired up and ran like new...So they can be checked and repaired, its just a case of finding the right person.
  • Tyrell Corp
  • Tyrell Corp's Avatar
20 Oct 2014 15:33
#651270
I've looked through the factory service manual plus later updates: it shows multimeter diagnostics and wiring diagrams of all the component parts but makes no mention of testing the ecu. Pre OBD ecu's on old cars can sometimes communicate by blink codes but I don't think this is an option here.
I guess it is a case of working through all the interconnecting component tests and if everything is ok the only solution is a suspect ecu.
  • Tyler
  • Tyler's Avatar
21 Oct 2014 15:18
#651358
that's how we did it in the automotive world. You would follow the trouble shooting tree diagram and if you made it through all of the component tests without finding a fault the last step was almost always “replace ecu"
I asked the OP if there was spark, or fuel, our neither because that can help determine were to start checking...
  • Tyrell Corp
22 Oct 2014 10:20
#651414
A lot of 'ECU faults' are an external wiring or sensor fault, assuming it is an EFI fault that is. Saying that, so many EFI bikes got changed to CV34 or other carbs over the years, I guess the ECU maybe not a massively sought after part.
Off topic, but some old Jap analouge electronic music gear I have is 1980's vintage and still works perfectly. So I think the quality of build was so much better for electronics in those days, and the old stuff lasts longer than the new.
If I get another kawi 1100 i'd like it wiith original EFI., so ahead of it's time then.
  • steell
  • steell's Avatar
24 Oct 2014 01:42
#651593
If you go to the 750turbo site there is/was some info there on repairing the 750 Turbo computer, and I suspect the Classic computer is probably simpler.
  • MFolks
  • MFolks's Avatar
24 Oct 2014 18:55
#651666
www.edlinecycle.com has these ECU's and other FI parts now and then.
