kawasaki kz1000 M1 wiring diagram
Re: kawasaki kz1000 M1 wiring diagram
16 Sep 2014 11:44stevie g wrote: It was in the filebase, and it isn't there now as previous guy said.
What are the key words being used in your search?
- Mcdroid
- Gone Kwackers
16 Sep 2014 11:45Patton wrote:Mcdroid wrote:Patton wrote: A FILEBASE Search for KZ1000M1 should include a clickable reference to the downloadable wiring diagram.
Broader FILEBASE searches such as KZ1000 should also include the same reference among lots of other references.
Can also insert a year in the search term, such as 1978 KZ1000 or 1978 KZ1000M or 1978 KZ1000M1.
The reason I ask is that if you go to Filebase and look under KZ documents and then under 'fours', there are only a few documents listed...I suspect stevie g looked that route, as did I. That is where they used to be, IIRC. Also, if you look under the drop-down menu with the Filebase link open and select KZ1000...very few documents are there. So, unless one uses the general 'Search' under filebase, many formerly easy-to-access documents are hidden.
That's why I use "Search Downloads" instead of "Select Category."
Yep...I know that now, but how does a brand new user/member know that?
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
16 Sep 2014 11:51 - 16 Sep 2014 12:28
For clarification, a FILEBASE search includes articles in the FILEBASE.
There's also another search feature under FORUM (i.e., a Forum search), which includes posts in the forum.)
Last edit: 16 Sep 2014 12:28 by Patton.
- stevie g
16 Sep 2014 11:52
Kawasaki kz1000 M1 when I looked at this originally it was in the filebase, under kawasaki fours, then i went into that and it was under the same name but with wiring diagram after it.
stephen g mackay
- stevie g
16 Sep 2014 12:00
I've looked there as well and cannot find anything. Maybe I'm doing something wrong, can someone else have a look for me and if you find it let me know where it is please,
stephen g mackay
- Mcdroid
- Gone Kwackers
16 Sep 2014 12:08
Go to Filebase tab, then you'll note a Search button at the bottom of the drop-down tab.. Click on that and type in KZ1000...you'll get a number of hits and towards the bottom of the list will be one file 'Z1000M1' of the wiring diagram.
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
- stevie g
16 Sep 2014 12:13
Got it. thanks mate,
stephen g mackay
16 Sep 2014 12:20 - 16 Sep 2014 12:25
As earlier posted, to download the M1 wiring diagram in kZr FILEBASE,
click here > www.kzrider.com/filebase/search/finish/1-general/240-z1000m1
With respect to forum topics and posts (as opposed to FILEBASE articles), here are 65 forum posts that mention KZ1000M1 --
Click > www.kzrider.com/forum/search?query=KZ100...te=all&childforums=1
Additional key words could be used to refine the search of forum posts.
Last edit: 16 Sep 2014 12:25 by Patton.
- stevie g
