DeoxIT - Which One ?
Re: DeoxIT - Which One ?
17 Sep 2014 05:00 - 17 Sep 2014 05:02
#647840
dkoz wrote: I purchased the gold. Do you think I'll get the same results?
I would use the D5 rather than the Gold. The manufacturer states "Recommended for critical applications where only slight cleaning action is necessary." Most of my connectors needed more than just slight cleaning. It probably is good to use on sensitive equipment that has gold plated connectors so the plating is not compromised, but that's not my KZ connectors. Here's the reference:
store.caig.com/s.nl/sc.2/category.292/.f
Last edit: 17 Sep 2014 05:02 by 650ed.
The following user(s) said Thank You: dkoz
  • Zephyrrider
  • Zephyrrider's Avatar Topic Author
17 Sep 2014 14:23 - 17 Sep 2014 14:24
#647869
Hi loudhvx - will check that today. I certainly have a brown on reg/rec and also have a spare reg/rec .
Thankyou.
Mick
1994 ZR750 Zephyr C4.
Last edit: 17 Sep 2014 14:24 by Zephyrrider.
  • Zephyrrider
17 Sep 2014 20:42
#647903
Reg/Rec test -
with ignition on for test - voltage at battery down to 12.3 - hardwired all dash lights and tail light on.
Original Reg/Rec - 11.8 volts.
Spare Reg/Rec - 11.9 volts.
Have D5'd everything i could get to on fuse box and that was only connectors and fuse holders - all spotless
Tried another Zephyr 750 fuse box and same results.
Might try that test without dash and tail lights on.
Mick
  • Zephyrrider
19 Sep 2014 13:15
#648083
Zephyr 750 charging system - Alternator Output Voltage - 31 Volts or More at @4000 RPM
Terminal Voltage - 12.6 Volts or more / Currently 12.6 - 12.9
Charging Voltage - 14 - 15 Volts @4000 RPM / Currently 14.8 - 15 @ 4000 RPM.
Mick
  • zero10
  • zero10's Avatar
22 Sep 2014 06:59
#648339
This thread reminded me that I really need to buy a can of this stuff. I found it on Amazon Canada for under $20 and is eligible for free shipping but is presently out of stock. I placed an order but haven't gotten a firm delivery date yet. Anybody know where to get it within Canada for a reasonable price?
  • loudhvx
  • loudhvx's Avatar
22 Sep 2014 07:13
#648341
Zephyrrider wrote: Zephyr 750 charging system - Alternator Output Voltage - 31 Volts or More at @4000 RPM
It's too high at 4000 rpm.
You should measure the voltage on the brown wire at the reg/rec. at 4000 rpm.
  • Zephyrrider
22 Sep 2014 14:12
#648365
Thanks loudhvx - will check that brown at 4000 the next day or so.
zero10 wherever you get it from there ya gonna get it for a good price. They only seem to stock D5 at 1 store i can find here and it is $49 plus post @$10 (142 grams) so of course i didnt buy it here. Got it from Caliifornia for $35 Total.
Mick
  • etbike3135
  • etbike3135's Avatar
22 Sep 2014 14:23
#648366
Does this D5 take mold off connections?
1973 Kawasaki Z1
18 years in dragbikes
  • pete greek1
  • pete greek1's Avatar
22 Sep 2014 14:28
#648367
I ordered mine from here, 5oz (142 gr.) for $14.99, & free shipping
www.google.com/aclk?sa=l&ai=CdkFqTJEgVM6...3D%2526network%253Dg
Pete
  • Zephyrrider
22 Sep 2014 23:41
#648441
that price is more like it pete greek1, we get ripped off big time here for loads of diff stuff.
etbike3135 dont know about mould - i didnt have any on connections - cant find any inside house to test it on either.
It does shift oxide well though.
Mick
  • Zephyrrider
22 Sep 2014 23:47
#648442
That is a good link pete greek1 for the D5. best price i have seen if you live in North America. Would cost me minimum $65 USD to get it here. Ebay was best in my situation.
Mick
The following user(s) said Thank You: pete greek1
  • zero10
  • zero10's Avatar
23 Sep 2014 07:38
#648467
Amazon Canada is only $20/can and is eligible for free shipping but is presently out of stock with no estimated date. I put in an order with them anyway, I don't need it until next spring so I guess I can wait a while. :P
