brighter replacement bulbs
- bountyhunter
Re: brighter replacement bulbs
05 Sep 2014 21:10
No eBay APP ID and/or Cert ID defined in Kunena configurationLED are pricey.
- zero10
05 Sep 2014 21:40
HID is from $35 to $70 for a single unit, LED is from about $75 to $180 per unit. Yeah they're pricey but if they give awesome light without overloading the charging system they are money well spent. I have no experience with them so really I can't say.
- saprophyte00
05 Sep 2014 22:21True...if my high beam hadn't been burned out when I got the bike...and the low was pretty dim so i just avoided riding Matilda at night. That night I got caught out a little later than I wanted. My fault for riding a bike that wasn't 100%, never again. And zero, I don't have an answer for your question, hopefully someone more knowledgeable will chime in. The specs between the wagner and napa match up, but... I can say that Line is right, and compared to the old Stanley that was in my bike, amazeballs is a definite understatement indeed!LineArtist wrote: Awesome find...!
BTW, when your headlight burns out you can always turn on your high beam bulb to get home safely. That's one reason I don't recommend to the chop project to get rid of that extra switch.
- bountyhunter
06 Sep 2014 00:06I don't have experience with LED, but I wonder about reliability. The first ones needed fairly substantial heatsinks on them. LED lights also require solid state switching converters to provide a constant current drive for the LEDs.zero10 wrote: HID is from $35 to $70 for a single unit, LED is from about $75 to $180 per unit. Yeah they're pricey but if they give awesome light without overloading the charging system they are money well spent. I have no experience with them so really I can't say.
06 Sep 2014 06:08 - 11 Sep 2014 05:29If your H4 bulb is dim, then something is wrong: dirty/cloudy lens unit? old/bad bulb? wrong/low wattage?? bad wiring or poor connections??? I went from a stock dim sealed beam to a halogen headlight from your model bike & it is plenty bright, and certainly brighter than the old original that was on my 81 650-CSR..zero10 wrote: I have a 82 KZ750H which has the H4 light with a replaceable bulb. I don't see too many recommendations for stock wattage replacement H4 bulbs, but the H6024 seems to be very highly recommended.....
I tried out the H4 on my bike and it is scary dim, utterly useless in my opinion and very very orange....
The Wagner unit is recommended because it's superior to the old dim stock sealed beam headlight that came on many models, mostly from the 70s. Yours came stock w a halogen headlight, so it should be good already.
If you still want to install the Wagner H6024, it should be a direct swap: if the swap works the other way, then it ought to work in reverse (see my reply on pg 1 ). You just remove the lens unit, H4 bulb, & maybe the dust cover, then install the sealed beam unit. It should be easy.
Last edit: 11 Sep 2014 05:29 by martin_csr.
- LineArtist
10 Sep 2014 19:26
I'm very disappointed to say my new Wagner H6024 low bulb has burned out in less than 2 weeks. Bad luck, poor shipping, factory seconds, I don't know.
Extremely disappointed.
and then this happened after noticing the light was out...
'79 KZ650B3 (stock)
'79 KZ650B3 (parts bike)
'06 HD 883R
'06 HD 883R
10 Sep 2014 19:46
It makes me wonder - obviously it could be just a bad bulb, but it might be worth running a quick check of the charging system (very easy to do with volt meter) just to make sure the regulator isn't letting too much voltage through. Also, if the rubber dampers in the headlight mount are old they may not be soft enough to dampen the vibration. These things are probably worth checking out before installing another bulb of any brand Ed
- daveo
10 Sep 2014 20:28 - 10 Sep 2014 20:31
1982 KZ1100-A2/1170 sleeper 😀
Last edit: 10 Sep 2014 20:31 by daveo.
- daveo
10 Sep 2014 20:30 - 11 Sep 2014 15:33LineArtist wrote: I'm very disappointed to say my new Wagner H6024 low bulb has burned out in less than 2 weeks. Bad luck, poor shipping, factory seconds, I don't know.
The Wagner 6024 I ordered came in the mail today, and was installed this evening. Come to find out the low beam on this one is bad too. The low beam shows light, but it is extremely dim. I've messaged the seller already, and hopefully he will simply send me another one. Otherwise, its back to old Stanley...
After double checking the connection, it now works...must have made inadequate electrical contact initially.
Last edit: 11 Sep 2014 15:33 by daveo. Reason: update problem status.
- bountyhunter
10 Sep 2014 22:06 - 10 Sep 2014 22:12Be sure to check voltage reg. If it is letting the system voltage go too high, it will kill bulbs quickly. Rev the engine to about 3K and the battery voltage should never exceed about 14.5V.LineArtist wrote: I'm very disappointed to say my new Wagner H6024 low bulb has burned out in less than 2 weeks. Bad luck, poor shipping, factory seconds, I don't know.
Last edit: 10 Sep 2014 22:12 by bountyhunter.
- bountyhunter
10 Sep 2014 22:10 - 10 Sep 2014 22:19Sounds like some kind of resistance in the path feeding the power to the bulb like the bulb's connector is corroded, harness connectors corroded, but also could be the high/low beam switch. The simple way to diagnose: turn the low beam on and use a voltmeter to read the voltages as you walk from the battery feed through the switches to the bulb.daveo wrote:LineArtist wrote: I'm very disappointed to say my new Wagner H6024 low bulb has burned out in less than 2 weeks. Bad luck, poor shipping, factory seconds, I don't know.
The Wagner 6024 I ordered came in the mail today, and was installed this evening. Come to find out the low beam on this one is bad too. The low beam shows light, but it is extremely dim. ...
Last edit: 10 Sep 2014 22:19 by bountyhunter.
- LineArtist
12 Sep 2014 11:16
Ebey seller started giving me a hard etime because the ebulb lasted about a week. Said his mechanic friend only puts Harley lights on the bikes he has worked on for the past 40 years. Contacted Wagner and they said they were aware the products are not being used solely on cars and if bought at a distributor the product would be exchanged for a new one.
I replied back saying I know at least 12 riders that swear by Wagner on their vintage KZ's. A new bulb is being sent to me as we speak.
'79 KZ650B3 (stock)
'06 HD 883R
'06 HD 883R
