- Thank you received: 9
RR question on kz750ltd w/ upgraded battery
- Jrbrownie00
82' kz750 ltd.
- kaw-a-holic
- Thank you received: 249
The way I look at, you should only ever have to buy 1 unless you wire it wrong. The battery should last longer than a lead acid so you are really ahead. Just my .02
Jon
1977 KZ1000a1
Mesa, AZ
Phoenix Fighter Project
- Thank you received: 1656
My 81 650 came stock w the same voltage regulator/rectifier as your bike --- I installed a used one from a low mileage 2007 Ninja 500: it's virtually identical to stock, but the connector is different (easy swap)(credit to loudhvx). The Ninja & Vulcan 500s have the same reg-rec up to 2009.
If you want to get a Mosfet, you might be able to get a new one on eebbaayy. For a while they were available for ~$49 --- there was a recall, hence the replacement (Kaw part #99999-0377). Because of the recall, you need to be careful about buying used (see pdf link below). You don't necessarily have to get one from a Kawasaki --- the other Japanese bikes also used mosfets, but I do not know if there was a recall on any of those (I think Shindengen is the only company that makes voltage regulators for the Big 4).
www-odi.nhtsa.dot.gov/acms/cs/jaxrs/down...CRIT-12V064-9756.pdf
- Thank you received: 2823
- loudhvx
- Thank you received: 1616
My buddy has gone through a couple on his Honda. They went up in smoke. He got another one with more heat-sink area and he added some vents to the body work to cool it, and it's been working ok.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
- Jrbrownie00
82' kz750 ltd.
- steell
- Jrbrownie00
82' kz750 ltd.
- koolaid_kid
- Thank you received: 99
This issue has been beaten to death over on GSR so I will not repeat all the technical details. If you want to know more, just visit there and look for threads started by posplayr.
1983 GPz 750
810 Wiseco, Kerker, K&N, DynoJet S3, Accel, Progressive, etc.
- loudhvx
koolaid_kid wrote: The biggest difference between the MOSFET and the series R/Rs is heat. The MOSFET will generate much more heat in the stator because the stator continues to run full tilt. The series R/R turns the stator off, saving your stator life.
I think you have mosfet mixed up with Thyristor (SCR). The series reg/recs use the mosfets. The shunting reg/recs use the SCRs.
1981 KZ550 D1 gpz.
Other links.
