1977 KZ1000 Brake Failure indicator switch
  • martin_csr
  • martin_csr's Avatar
Re: 1977 KZ1000 Brake Failure indicator switch
31 Mar 2014 07:27
#627201
Thanks. I was hoping to encapsulate the diodes & resistor for the HEI igniter, and your warning switch is pretty much the way I was thinking of doing it. The form you made is very helpful. Thanks. JMK.
  • bountyhunter
  • bountyhunter's Avatar
31 Mar 2014 12:26
#627232
We always had a can of clear silicone rubber for potting. I would dip the board in it. Epoxy is OK but when it cures the expansion can sometimes stress the components it is around. I have used Epoxy sometimes but the rubber is less rigid.
  • chconger
  • chconger's Avatar Topic Author
31 Mar 2014 14:00
#627249
Never considered that. Now that you mentioned it, I did a quick bit of research (as far as Wikipedia anyway) and it says that epoxy is not used for surface mount electronics for this reason. Looks like older thru hole tech (like this) is OK. I know a lot of power bricks are in epoxy and the old Kawasaki switch I pulled from the bike was certainly in epoxy.
Besides, things look cool in "amber";
Yea... nobody but us will ever see it :)
Cheers
Chris
1977 KZ 1000-A
  • chikosneff
  • chikosneff's Avatar
08 Aug 2017 01:23
#768561
hey chconger I am about to do the same thing, unfortunately, your pictures are gone do you still have them around? Thanks!
1978 KZ400 B
  • martin_csr
08 Aug 2017 05:14 - 01 Sep 2017 06:10
#768564
The first two images are from this topic. not sure about the last one, but I believe it is. I forgot to add text to it. doh.
Last edit: 01 Sep 2017 06:10 by martin_csr.
  • Gray17
  • Gray17's Avatar
23 Apr 2023 04:38
#883593
I have read your article with interest, i am currently restoring a KZ900 and it doesnt have the brake light relay, but does have the warning lamp. Looking at the circuit it looks simple enough to make, but do have a few questions.
1. What is J1 on the diagram?
2. What is T2 on the diagram?
3. Obv i know what resistors are but what are their tollerance and rating 1/4w, 1/2w? or doesnt it matter.
4. What type of capacitor electrolytic, polyester?  Assume 16v will be ok.
Thanks
