2 and 3 intermittently dying
  • who8myrice
  • who8myrice's Avatar Topic Author
27 Oct 2013 12:49
#611317
Im having a really hard time diagnosing my bikes problem. The #1 and 4 cylinders always run perfectly and the bike always starts on the first kick. However the #3 cylinder will not run at all and I cant really tell but it seems like the #2 cylinder is either running intermittently or not running at all. Carbs and air filters are definitely clean and working. No vacuum leaks, new battery, no exhaust leaks. I checked both coils and the resistances were within spec (slightly high, primary was about 5 ohms). Both coils are only getting about 9.2V because of bad wiring which ive been meaning to replace, but ive checked all 4 spark plug wires with an extra plug while the bike is running and all 4 plugs have a good constant spark that could jump a .5" gap to the engine. What am I missing here? The #3 cylinder plug was black and wet, the #2 was slightly less black but still wet.
1979 Kz650, 4-1 V&H, Pod filters
  • 4TheKZ1000
  • 4TheKZ1000's Avatar
Re: 2 and 3 intermittently dying
27 Oct 2013 13:31 - 27 Oct 2013 13:34
#611320
ok what bike
make?
model?
size?
year?
points?
dyna-s?
Last edit: 27 Oct 2013 13:34 by 4TheKZ1000.
  • who8myrice
27 Oct 2013 13:37
#611322
Right- sorry!
1979 KZ650, dyna s ignition, 4-1 vance and hines exhaust with pod filters, mikuni VM24SS carbs with accelerator pump
  • 4TheKZ1000
27 Oct 2013 13:45
#611323
ok,
so we have two coils. 1 and 4 for one coil and 2 and 3 for the other. Sounds like you are having no spark from one of the coils.
The dyna-s will have two power wires that feed both coils.Do you have both sides of the dyna-s going to power?
  • who8myrice
27 Oct 2013 14:13
#611327
I think so but the previous owner installed it so i will check. But the thing is the 2 and 3 cylinders both have spark. I fired up the engine, pulled the #3 plug wire and plugged in an extra spark plug i had lying around and grounded that against the engine and it produced a constant steady spark. Repeated those steps for the #2 cylinder and it too had spark. This is why im confused.
  • 4TheKZ1000
27 Oct 2013 14:24
#611329
could the coil be grounding out on the frame.....this is a very common problem with dyna coils. Please re-check the power wires and the crimp on connectors.
There are several forum members that forgot more than I know......just be patient, someone will figure it out.......could take a while.
  • 4TheKZ1000
27 Oct 2013 14:28
#611331
Here is the tech download page for your Dyna-s.......ck this out for info, might help you.
www.dynaonline.com/skins/downloads/Default.aspx
  • who8myrice
27 Oct 2013 14:32
#611332
No the wires are definitely OK, ive double checked. Also they are not dyna coils, they appear to be the original TEC coils.
  • 4TheKZ1000
27 Oct 2013 14:44 - 27 Oct 2013 16:01
#611336
Ok,
on my bike.....I cant use stock coils with a dyna-s.
The stock coils on a kz1000 are rated 2.8 ohms and the dyna-s requires that you use 3.0 ohms. It dosent sound like a big difference but it is.
This might be a problem. Do you know 100% you can use the stock coils with a dyna-s ignition?
Last edit: 27 Oct 2013 16:01 by 4TheKZ1000.
  • who8myrice
27 Oct 2013 14:51
#611340
I'm really not sure, i'll try to find out. But the 1 and 4 coil seems to be working fine so I want to say yes. My multimeter reads 5.2 ohms across the primary coil.. but maybe the multi is bad. Also like I said im only getting 9.2v at both coils, but i still consistently have spark on all 4 cylinders. Its very strange.
  • 4TheKZ1000
27 Oct 2013 14:59 - 27 Oct 2013 15:07
#611342
who8myrice wrote: I'm really not sure, i'll try to find out. But the 1 and 4 coil seems to be working fine so I want to say yes. My multimeter reads 5.2 ohms across the primary coil.. but maybe the multi is bad. Also like I said im only getting 9.2v at both coils, but i still consistently have spark on all 4 cylinders. Its very strange.
_________________________________________________________________________________________
I just looked on Dyna website and found the DS2-2. This is the dyna-s for your bike. It said you need to use DC1-1 which are the 3 ohm coils.
Last edit: 27 Oct 2013 15:07 by 4TheKZ1000.
  • P21
  • P21's Avatar
27 Oct 2013 14:59
#611343
you might have some valves hanging open (no clearance) on header side
what compression numbers look like on them cylinders?
Kawasaki KZ 1000 Police (2002) P21
