Trouble Starting My KZ LTD 440 1982
- prizethedoubt
01 Oct 2013 20:57
Hey folks,
I'm new to the motorcycle world and this is my first bike. I will do my best to describe what is happening.
Basically I am getting the click sound when trying to start my bike ( no kickstart ). I replaced the spark plugs, changed the oil, and have a full charge on the battery (around 13v)
The bike rode home fine for 50 mins, aside from heating up at one point because the bike was low on oil, and the choke was on too high.
I am hearing the click sound from the left side, around the solenoid. Not sure what I need to replace. I was able to start the bike a few days ago but since then I am getting less and less response from the starter, and now I have nothing but the click sound.
please help!?
-Alex
please help!?
-Alex
Attachment mybike.jpg not found
KZ 440 LTD 1982.
Re: Trouble Starting My KZ LTD 440 1982
01 Oct 2013 21:26
Have you tried bump starting (push starting) the bike to make sure the engine turns over ok? Ed
- prizethedoubt
01 Oct 2013 22:00 - 01 Oct 2013 22:01
Would get the battery load-tested -- usually for free anywhere batteries are sold, such as Walmart, AutoZone, etc.
Meanwhile, it's okay to try a brief jump start from a good automobile battery PROVIDED the automobile ignition key is removed and the automobile engine is NOT RUNNING.
If the engine cranks over normally when jumped to the automobile battery, but fails to crank over normally when using only the bike battery, then the bike battery is likely at fault, regardless of its voltage reading.
Last edit: 01 Oct 2013 22:01 by Patton.
- prizethedoubt
01 Oct 2013 22:43
Ok, I will try and jump it. With the car off
KZ 440 LTD 1982.
- prizethedoubt
01 Oct 2013 23:30
no change trying to jump the bike with the car battery. click.
KZ 440 LTD 1982.
02 Oct 2013 00:05
Since you said it overheated due to a lack of oil, I would try jump starting it just to make sure the engine is free to turn over. Ed
- prizethedoubt
02 Oct 2013 10:46
I'm going to try push starting the bike down my driveway next. So I put the bike in second gear, hold the clutch, ride down the hill (it is pretty steep) hit top speed, release the clutch,(hopefully starting the bike) then hold the clutch again to counter losing control correct?
-Alex
-Alex
KZ 440 LTD 1982.
02 Oct 2013 11:45 - 02 Oct 2013 11:46
Yes. First gear will work too if you cannot select second gear. Ed
Last edit: 02 Oct 2013 11:46 by 650ed.
- prizethedoubt
07 Oct 2013 16:19
No luck with the push start. Any suggestions? Should I check out the starter/buy a new solenoid?
KZ 440 LTD 1982.
07 Oct 2013 16:27
When you tried push starting it, could you hear the engine turn over? If so, at least you know it's not seized. Ed
- turboking
07 Oct 2013 17:29
:pinch: put the bike on the center stand and put the trans in a higher gear (3rd or 4th, 5th) you can turn the engine over by using the rear wheel.... :blink: it may be easier to remove the spark plugs then you do not have to fight the compression of the engine...just to be sure the engine is not seized/locked up :huh:
2005 Kawasaki mean streak
1979 kz 1000 mk II ATP turbo
1975 Z1 960 cc Mr. Turbo
1976 Kz900 1103 cc ATP turbo
1985 GS 1150E
1983 GS 1100E
1997 Suzuki Bandit 1200S
2001 Kawasaki EX 500 Ninja
1985 GS 1150E
1983 GS 1100E
