- Thank you received: 13
Camshaft sensor for ECU
- The_Proletariat
- "Cocaine is a hell of a drug"
1982 Kawasaki KZ550 LTD
- 750steve
07 ZX6R Race Bike
1977 Z750 B2 Twin
1976 Z650 B1
- steell
As for throttle bodies, it gets confusing. GPz750 Turbo uses 33mm and GPz1100 34mm (I think). They were early fuel injection and Kawasaki used throttle bodies comparable to carb sizes. Later fuel injected models used much larger throttle bodies, 43mm for the ZX10R, and 46mm for the ZX12. Early fuel injected Yamaha R6 used 38mm CV throttle bodies (the only CV throttle bodies I've seen) while the Suzuki 600/750/1000/1300 early models all used the same 42mm throttle bodies.
The best thing about the GPz throttle bodies is they'll bolt right on, but they may not allow maximum power. Others require a bit of work to fit.
Kind of leaves you scratching your head, don't it? :laugh:
- Lorcan
- Speed Loony
- Thank you received: 59
The DTA S60 is excellent. A pal of mine runs one on his 240+mph 600hp ZZR1100.
760cc - 8.69@162mph
810cc, 211mph www.750turbo.com
www.stormdragbike.com
- steell
Seems like I read that on your site a long time ago.
What throttle bodies do you have on the 750 Turbo?
Again, IIRC, it was cranking out ~256 RWHP?
- Lorcan
- Speed Loony
The bike made 235hp with a boost leak just before it ran 195mph. It wasn't dynoed again after the boost leak was fixed and it ran 211mph, but it was probably around the 250hp mark.
Jeff's make recorded 255hp on the dyno with a similar setup.
760cc - 8.69@162mph
- 750steve
07 ZX6R Race Bike
1977 Z750 B2 Twin
1976 Z650 B1
- ChevyDK
I wonder what you use for crank sensor?
The Stock sensors or some kind of 36:1 triggerwheel with a sensor?
- steell
Since I'm here
The ZX12 is just an engine spread out across a workbench with a big pile of boxes containing new engine parts (including MS3). The ZZR1200 engine is sitting in a cradle beside the ZX11 waiting on me to finish the top end and flip it over for a bottom end inspection.
Over a year now and nothing's changed !!! :blush:
