Main fuse amperage?
- phillyman2633
Warning: Novel alert
I noticed my tail lights were out on my '82 KZ750N Spectre the yesterday. I was hoping it was just the bulbs (both were out) so I took it to AutoZone and got some bulbs and put them in there with some terminal grease. When I turned on the key, they were still out, so that wasn't it. I figured (was hoping) that is was just the fuse, but I didn't have any spares, so I took the headlight fuse out and when I went to put it in the tail light slot, my dumb ass (I can't stress that enough) stuck it between the 2 slots and I guess I shorted the fuse myself, I saw a little arcing so I hope I didn't f anything up. So now I'm stranded in the parking lot with multiple blown fuses. Of course AutoZone was out of 10A, 20A, and 30A fuses, so I was f$&%ed and ended up having to trailer it home. What a cluster.
I notice that on the fuse panel cover, it says the main fuse should be 20A. I look at the one that had been in there, and it was a 10A. Now I'm looking at the service manual, and it calls for a 30A main fuse. So the fuse panel and service manual contradict each other and I have been running it on a 10A fuse since I bought it 2 weeks ago with no problems, so you can understand my confusion here at least. Oh, and the tail lights DID work up until I noticed they were out yesterday. Anyone know which it should actually be?
Sorry for long-windedness.
Democracy is nothing more than mob rule, where 51% of the people may take away the rights of the other 49% - Thomas Jefferson
- Thank you received: 2829
Attachment 00000_2013-07-31-2.jpg not found
- phillyman2633
- MFolks
- Thank you received: 540
- Thank you received: 1656
phillyman2633 wrote: That's what I thought but I wasn't. Also, the wiring diagram shows 2 10A fuses that aren't in the fuse box, they look like they're off the battery but I can't seem to find them. Any idea where they might be?
Those are probably the accessory fuses. The acc fuse box on my bike is kinda hidden behind a mounting tab for the left side cover. It fits onto a bracket. Usually, one acc lead terminates near the electro stuff (black/white wire) & the other one terminates at the headlight bucket (blue/white wire).
As for the 30A fuse, that seems odd to me. And odd that Kawasaki wouldn't provide a fuse box w the correct amperage embossed in the thing. Checking the cross-ref, the 750-Shaft models are the only 750s w a 30A main fuse. There didn't seem to be anything much different about the electrical stuff compared to some other 750s, but I probably missed something. Maybe something to do w the ignition system or something on the shaft drive models?
- phillyman2633
What fuses do you guys run in your bikes? Are AGX compatible in the AGW slot? This is ridiculous that they're this hard to find.
- Motor Head
- Thank you received: 391
Also you can upgrade and go to a ATO style of fuse panel. Do the rewire once, and then carry the modern fuses which are everywhere. They don't get hot and come disconnected at the end caps either.
- MFolks
www.pepboys.com/product/details/122975/00566/?quantity=1
- phillyman2633
Motor, I was actually thinking about doing that. Do you know where I'd be able to find a drop in replacement for the fuse box assembly that would take the ATO fuses?
- Motor Head
- kzz1king
- Thank you received: 52
Wayne
Home built KZ1000 turbo setup
