1982 spectre 750
  • nitrokrumpt
  • nitrokrumpt's Avatar Topic Author
  • she just looks rough now
1982 spectre 750
13 Jun 2013 18:13 - 13 Jun 2013 18:15
#592129
so with this bike even in neutral you need to pull the clutch in to start. it sorta stalled on me in first gear, so pulled the clutch in not in "neutral" and she started no problem, wanting to pull forward a little but figured thats normal. she started up ran fine for 5 min. i stopped the engine parked it for 15 min while i came back to the best forum made (kzrider) go back out and she doesnt turn over now. everything lights up, just no crank once so ever. when i pull the ignition switch from off to run you can see in the tach a tiny jump in the needle but no crank. battery is brand new and currently with a charge of 12.80
1982 kz750-n1 spectre
Last edit: 13 Jun 2013 18:15 by nitrokrumpt. Reason: spell check
Re: 1982 spectre 750
13 Jun 2013 18:24 - 13 Jun 2013 18:25
#592132
To my knowledge every KZ requires you to pull in the clutch to use the electric starter regardless of whether the tranny is in neutral or in gear- it's a safety feature. Ed
Last edit: 13 Jun 2013 18:25 by 650ed.
  • nitrokrumpt
13 Jun 2013 18:44
#592139
oh crap...you think i blew something? because ya i totally started it in 1st gear and now she dead. thanks big ed
  • martin_csr
  • martin_csr's Avatar
13 Jun 2013 18:59
#592142
It doesn't hurt anything to start it in 1st. Or any other gear for that matter.
Make sure the kill switch is set Run.
  • nitrokrumpt
13 Jun 2013 19:12
#592146
yes kill switch is on run and im pushing it to start and there is nothing all of a sudden too. like i said switching the kill switch from off to run i see a tiny jump on the tach needle...
13 Jun 2013 19:24
#592148
When you push the starter button with the tranny in neutral, the key on, the kill switch in "RUN", and the clutch lever pulled in does the green neutral light or other lights dim? Ed
  • Motor Head
  • Motor Head's Avatar
13 Jun 2013 21:36 - 13 Jun 2013 21:37
#592165
First check your fuses, with a meter or test light. Don't just look at them, make sure they are good and power on both sides.
Last edit: 13 Jun 2013 21:37 by Motor Head.
  • nitrokrumpt
13 Jun 2013 21:50
#592169
hey guys thank you...i dont know what happened but i pulled out the clutch lever adjuster on the handle bar as far as it would go out and nothing...took off the grip (so clutch pulls in more) and she started right up...easy fix and should be able to fig the rest lol.
  • Motor Head
13 Jun 2013 22:07
#592175
Check where the switch goes into the perch, make sure it is in correctly.
Do you have some big dia grips or something? Might end up needing a new clutch safety switch.
  • nitrokrumpt
13 Jun 2013 22:11
#592176
i guess they are bigger grips...hey motorhead i sent you a private msg
  • P21
  • P21's Avatar
13 Jun 2013 22:12
#592178
not sure of 82 model but mine has side stand safety switch also
Kawasaki KZ 1000 Police (2002) P21
  • Motor Head
13 Jun 2013 22:13
#592179
nitrokrumpt wrote: i guess they are bigger grips...hey motorhead i sent you a private msg
Answered
