I think I have a bad IC Box
  • Mark Wing
  • Mark Wing's Avatar Topic Author
Re: I think I have a bad IC Box
27 May 2013 17:22
#589467
Paul that would be great if you mail it to me, it looks like it's the problem. I ran the bike on the battery only with the charging system unhooked I still had the problem.
Mark
Yorba Linda Cal.
  • baldy110
  • baldy110's Avatar
28 May 2013 11:53
#589578
Shipped this morning, FYI you are going to need to to use one of your connector ends because I cut the end off and used it to hook up my Dyna S but the unit is good. Hope it fixes your problem.
  • Mark Wing
28 May 2013 21:26
#589634
Thanks, the end change is no biggie.
Mark
Yorba Linda Cal.
  • greenman43
  • greenman43's Avatar
31 May 2013 10:36
#590085
My long-gone '77 Z1000 had the same kind of problem, revved cleanly then started to break up at about 6500-7000. After trying a lot of other things, I had my mechanic lube the spark advancer, which completely solved the problem - presume your 750 has the same system ,so worth a look.
Cheers,
Brian
1980 Z1000 A4 Mk II
2007 ZX10R 'SL' (superlight)
1989 GPz900R
  • kimsmith4807
  • kimsmith4807's Avatar
01 Jun 2013 19:16
#590321
Struggled with IC ignitor issues last year. My manual (1981KZ1000-K1 LTD) has good troubleshooting checks for it but must use an analog meter to get the correct readings. Lots of folks told me my problem wasn't my ignitor, that they rarely fail. Again, going by the readings and findings from my manual mine was bad. Had a jumping tach too. So, a nos ignitor isn't available and buying a used one from ebay is taking a chance. Upgraded to the Dyna S system. Simple to install, affordable and absolutely fixed my problems. Fixed my jumping tach as well, rock steady now. Good luck with your problem, just wanted to pass on the Dyna S is a suitable option.
1981 KZ1000-K1 LTD
  • loudhvx
  • loudhvx's Avatar
02 Jun 2013 00:39
#590382
I'm surprised to hear the igniter is not available. The police bikes used them well into the 1990's, and the pickups are still available. (Cannot check Kawasaki.com right now, the site seems to be down.)
But either way, they were $500+ last time I checked.
You can always make one for about $50. The link is in my signature.
  • Mark Wing
02 Jun 2013 18:57
#590505
Thanks Paul the new box you gave me did the trick, no moor stumble.
Thanks Mark
Yorba Linda Cal.
  • baldy110
  • baldy110's Avatar
02 Jun 2013 20:21
#590519
Your welcome, I have two more if you need a spare, I'm no longer using the OEM ignition on mine.
