Worn Starter = Dead Battery?
- freakinbike
20 Mar 2013 02:52
My 1982 GPZ750 has been having carb trouble for awhile. I know this is the main reason for it having trouble starting. But recently, my starter has been making the most awful grinding noise. Must be worn out, time for a new one. However, it still starts the bike... occasionally. Most of the time, I'll press the start button and it will crank a couple times, grind, crank, then die. This is a brand new battery, installed it last week.
I know I need a new starter, but is that what's killing the battery? Also, if anyone has recommendations for starters, I'd love to hear them.
Thank you!
Note: I've been seeing a few starter threads, sorry if this is redundant.
Thank you!
1982 GPZ750, stock (for now..)
1973 VW Bus
Can life really get much better?
1973 VW Bus
- 0Z.Z1R Mk2
Re: Worn Starter = Dead Battery?
20 Mar 2013 06:28
Had a similar problem/noise with my GPZ starter motor.
After pulling it out,I found 25 years of carbon build up.
Gave it a clean out and its been working fine for the last 5 years.
1976 KH 500 triple
1978 Z1R D1
1980 Z1R MK2
1983 Gpz750 turbo
2007 ZRX 1200r
1982 GSX 1000S Katana
1983 GSX 1000S Katana
Don't knock my turbo lag - it gives your naturally aspirated a chance..
1978 Z1R D1
1980 Z1R MK2
1983 Gpz750 turbo
2007 ZRX 1200r
- baldy110
20 Mar 2013 12:08
That sounds like your starter clutch going bad not your starter.
- freakinbike
20 Mar 2013 15:39That sounds like your starter clutch going bad not your starter.
Is that what's killing the battery, too? Or just the grinding?
1973 VW Bus
1973 VW Bus
- freakinbike
20 Mar 2013 17:20
I figured out how to phrase this question in a way that actually makes sense.
Can a worn starter (or starter clutch) put unnecessary draw on the battery?
1973 VW Bus
1973 VW Bus
20 Mar 2013 18:09
I don't believe a worn starter clutch would cause the battery to drain since they normally just spin and make a lot of noise when they need to be rebuilt.
However, I suspect if the starter is really dirty or damaged it could draw an unusually high level of current from the battery, and that might contribute to wearing down the battery charge prematurely. Assuming your bike's starter is like mine, the circuit to it is not fused, so it can draw a lot of current before something (like the wiring to it) actually smokes. Ed
- freakinbike
20 Mar 2013 21:56 - 20 Mar 2013 22:07
I tore the sucker apart and there is so much carbon buildup inside of the starter motor. The armature has the most buildup so I'm wondering.. can I drop the whole thing inside carb cleaner? Not the the wires and outside casing, but just the armature.
1973 VW Bus
1973 VW Bus
Last edit: 20 Mar 2013 22:07 by freakinbike.
20 Mar 2013 22:19
I wouldn't do that. I would try to clean it dry using a brush. Don't treat it too rough. Ed
- Topper
20 Mar 2013 22:24
If you use anything try some electrical contact cleaner. You can sand it with some emory paper too.
Permanent and perpetual noob.
1979 KZ750 Twin
2009 Kawasaki Versys
1979 KZ750 Twin
- Topper
20 Mar 2013 22:46 - 20 Mar 2013 22:47
BTW, does it sound like this?
1979 KZ750 Twin
1979 KZ750 Twin
Last edit: 20 Mar 2013 22:47 by Topper.
- freakinbike
21 Mar 2013 00:52Yeah, similar to that.BTW, does it sound like this?
So, like I said, I tore the starter motor apart. I cleaned it all up, greased it, and reinstalled it. I took the voltage of the battery: 11.5ish volts. Shouldn't it be higher? I try to start the bike: nothing. Read the voltage again: 9 volts. I left the key on: 8.5, 8, 7.5, 7.. seriously, within three seconds I was down to 7 volts. I pressed the starter again, the volt meter reads 2.7 volts. Released the starter, back to 7 then draining again.
First off, should the starter be pulling 5-or-so volts?
Second, is a headlight and four blinkers really enough to drain the battery like that??
1973 VW Bus
1973 VW Bus
- MFolks
21 Mar 2013 01:09
I'd fully charge the battery, and then have it load tested(most motorcycle shops and auto parts stores can do this for you). If you can get 5 years out of a motorcycle battery, consider yourself lucky.
