Instrument panel bulbs - Eiko alternative?
  • faceplateman
  • faceplateman's Avatar
Re: Instrument panel bulbs - Eiko alternative?
23 May 2013 13:25
#588896
would an auto parts store have replacements?
1979 kz650 b3
  • martin_csr
  • martin_csr's Avatar Topic Author
23 May 2013 13:43 - 24 May 2013 10:00
#588899
Yes. Unless you mean the LEDs, then I don't know.
I installed the Eiko 1891 bulbs. The packaging says "heavy duty", so hopefully they'll hold up for a while.
Last edit: 24 May 2013 10:00 by martin_csr.
  • BlueKaw
  • BlueKaw's Avatar
28 Oct 2017 08:09
#773896
Did the 1891 ulbs work ok for you? I have a 81 csr 1000 and I just bought 1889 bulbs. They are supposed to be a little brighter. Just wanted to see how the 1891 brightness was as compared to the originals.
Thanks
Old Kaws never die.
  • martin_csr
28 Oct 2017 11:52 - 28 Oct 2017 11:53
#773906
Yes. If you've never replaced the meter bulbs, the sockets can be a bear to remove because of the old rubber. LEDs nowadays are probably a better option as you'll probably never have to replace them..
Last edit: 28 Oct 2017 11:53 by martin_csr.
The following user(s) said Thank You: BlueKaw
