Spectre 750 Rear Tail Light/Brake Light Question
  • bull durham
  • bull durham's Avatar
Re: Spectre 750 Rear Tail Light/Brake Light Question
21 Aug 2012 17:16
#543939
almarconi wrote: I had a chance to work on the bike this weekend. Disconnected the blue wire at the tail light and the running lights worked (only one filament is lights up). Reconnected the blue wire and both filaments light up. Disconnected the rear brake switch at the connector and one filament lights up. Apply front brake and both filaments light up. So now the front brake is working. Looks like bull durham was correct the rear brake switch was the problem. When I reconnected the rear brake switch both filaments light up regardless of the brake pedal being applied. I will see if I can take the rear switch apart and clean it. If not I'll just replace it. I also noticed that my charging system works better now, I could not get about 13 volts at the battery. Now with only one set of filaments light up the battery voltage is closer to 14 volts. Thanks for all your help.
Hey, that's good news, glad to hear it.
Bull Durham
VBA #1608
2005 Kawasaki Nomad
1979 Kawasaki KZ 750
1975 Kawasaki Z 900
1965 Honda C110
1978 Kawasaki KZ 1000 (sold)
1976 Kawasaki KZ 900 (sold)
1973 Kawasaki Z 900 (sold)
