Orange spark plug deposits
  • Ktm181
  • Ktm181's Avatar
  • Man made it, so Man can fix it
Re: Orange spark plug deposits
17 May 2012 21:30 - 17 May 2012 21:32
#522993
Hey mate, looks like a nice Z you have there.
MIne is a 1075cc wiseco and cranking pressure is up near 190psi depending on who's gauge i use, 98 BP is excellent, no knocking at all, no signs of detonation on either piston OR plugs etc. If its a stock engine 95 in Aus is fine, (its around 91 in the U.S. PON method) it will even run ok on E10 but your hoses,filter and tank internals might not like it, hoses can go hard and so can the filters become brittle (over time), E10 will also clean the inside of you tank! The orange on your plugs is quite common depending on what additives are in the fuel you are using, apparently manganese is one of the additives used to help with valve recession and it can turn plugs orange, we see it on the car plugs where i work but not every car.
I am in Sydney by the way and use BP98 octane ALL THE TIME unless on a long ride and cant get it, it still runs on the others but it LOVES BP98, Shell 98 etc.
Almost forgot, our heads are set up to use UNLEADED from the word GO! 98 fuels down here (& 95) have stuff added to help with valve recession, i am told the E10 and normal standard unleaded does NOT.
regards,
Kt
Last edit: 17 May 2012 21:32 by Ktm181. Reason: FORGOT SOMETHING!
17 May 2012 22:05 - 17 May 2012 22:06
#522998
:unsure: Am vaguely recalling that the lead additive had the effect of "padding" the valve seats against the constant pounding of the valves, and that the "unhardened" valve seats in some older engines reportedly wore out sooner when burning unleaded.
Good Fortune! :)
Last edit: 17 May 2012 22:06 by Patton.
  • KZ1000inaus
  • KZ1000inaus's Avatar Topic Author
  • Luminous Red KZ1000 A2
17 May 2012 22:57
#523011
Ktm181 wrote: Hey mate, looks like a nice Z you have there.
regards,
Kt
thanks mate, it's gonna look a lot finer when i finally get it re-sprayed to it's original Luminous Red.. (if i can persuade the missus to let me shell out a grand on the paint job)
and thanks for the Oz info. I notice a local "Nationwide" servo selling 100 octane only to find that 10% of it is Ethanol !
