return to points
  • Rev
  • Rev's Avatar Topic Author
return to points
10 May 2012 23:24
#521385
My dyna s ignition died for the second time, so I am reverting back to points (at least for now). My question is can I still use my Dyna 3ohm coils and cables with the points?
78 kz650, Maxi-dwell, Modified flow through air box, Dyna coils.
  • MFolks
  • MFolks's Avatar
Re: return to points
11 May 2012 00:00
#521402
I see no problem,primary(small wires) side of the coils will read between 1.8 to 3.0 ohms. Some of the higher performance seekers are using the 2.2 ohm Dyna coils, but it's only useable at very high rpm's
  • Rev
11 May 2012 00:08
#521405
Thanks I was hoping I could use them.
Bill
  • Motor Head
  • Motor Head's Avatar
11 May 2012 10:33
#521516
Have you contacted Dyna about the Ignition failures? Seems like they would warranty the Ignition for you.
Another avenue would be getting a later model Kaw setup, as they are quite stout and reliable.
  • loudhvx
  • loudhvx's Avatar
11 May 2012 11:16 - 12 May 2012 13:36
#521522
Have you ever put a volt meter on the battery to make sure the charging system isn't putting out too much voltage? If it's over 15v, then something is wrong... (possibly the regulator).
Last edit: 12 May 2012 13:36 by loudhvx.
  • bountyhunter
  • bountyhunter's Avatar
11 May 2012 16:09 - 11 May 2012 16:12
#521578
Rev wrote: My dyna s ignition died for the second time, so I am reverting back to points (at least for now). My question is can I still use my Dyna 3ohm coils and cables with the points?
I don't think so. The coil will dissipate too much power and cook. The low impedance (less than four Ohm) coils are OK with electronic ingitions because the coil is not "on" continuously, but with points, the coil current flows a larger percentage of the time and if you leave the key on for any period of time not running... it can be on 100% which will fry it.
Z1 sells a 4 Ohm Emgo coil for use with points that costs $36. It's the one I have been running for about 5 years, works fine.
Last edit: 11 May 2012 16:12 by bountyhunter.
  • rstnick
  • rstnick's Avatar
  • Premium Member
  • Premium Member
11 May 2012 23:54
#521701
From Z1enterprises' site:
"Never select a coil with a lower resistance than your ignition system - this will cause the coils to overheat and burn out... It is OK to select coils with a slightly higher resistance. For example 3.0 ohm coils with a 1.5 ohm CDI ignition. While this isn't optimal, it works and allows you to switch your CDI ignition over to a Dyna-S in the future".
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
  • loudhvx
  • loudhvx's Avatar
12 May 2012 03:40
#521744
Actually, the Dyna S dwell is well over 300 degrees. The points are around 180 degrees. So if the coils can handle the Dyna S, they can surely handle the points.
The points, however, will have a shorter life with the 3 ohm coil over the 4 ohm coil, but will still work. Many have run 3 ohm coils with points.
In the case of leaving the ignition on, with the motor not turning, in extreme cases, people have reported coils melted into a blob of plastic and copper... definitely bad.
  • roy-b-boy-b
  • roy-b-boy-b's Avatar
12 May 2012 05:54
#521750
loudhvx wrote: Have you ever put a volt meter on the battery to make sure the charging system is putting out too much voltage? If it's over 15v, then something is wrong... (possibly the regulator).
Do this first! If there is voltage spikes you will just be burning up points. Make sure the ground from the voltage regulator is getting a good ground. Roy
  • Old Man Rock
  • Old Man Rock's Avatar
12 May 2012 10:04 - 12 May 2012 10:05
#521759
Maybe I'm just been lucky with my Dyna... :)
From a technical perspective I'm with Loud on this one where why did it kill two EI units... Something is just not right here and I'd be looking at the charging/regulator for as mentioned, should be no higher then 14.5Vdc output regardless of the crank rpm...
If more then that, yup, going to cook something else sooner or later...
Just my two worthless cents...
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
Last edit: 12 May 2012 10:05 by Old Man Rock.
  • Zedone
  • Zedone's Avatar
13 May 2012 20:01
#522127
I have older Andrews 3 ohm coils (blue in color) and older Blue Max plug wires using the stock ign (points & condensers) And it works fine. I did notice the plug wire silicone jackets near the plug boot were turning brown (all 4). So, I believe they are running much hotter. I have a Dyna S ign but still need to install it. So, it will work but it could poss. overload part of your elec system.
I would go over your Ign wiring and look for a gremilin. It could be you had bad luck with 2 bad Dynas, but the odds are pretty rare.
1977 KZ1000A1
1977 KZ1000A1 (Superbike Project)
1969 Chevrolet C/10 Short Fleet
  • bountyhunter
13 May 2012 21:48 - 13 May 2012 21:50
#522153
MAKE SURE YOU UNDERSTAND THIS:
Electronic ignitions work by having some kind of transistor switch in series with the coil primary. Ergo, there is significant voltage drop across the transistor which reduces the voltage across the coil. That's why elect ignitions went to lower resistance coils: to compensate for the voltage lost, keeping the coil's current fairly constant.
If you use a low impedance coil with points, that put's the full 12V across it (14V engine running) which it was not designed for. It also increases the current through the bike's wiring to a level it was not designed for. Power dissipation in the coil is proportional to voltage SQUARED so the heat increase is significant.
maybe Dyna "overdesigns" it's coils so much they can handle the full 14V system voltage? I would not think so, but maybe. But your bike's wiring and alternator weren't designed for it.
This is the reason Z1 offers this warning:
Last edit: 13 May 2012 21:50 by bountyhunter.
