Kz 750 twin charging
- Kz twin
Re: Kz 750 twin charging
04 May 2012 02:27
So I rewired again went over it to many times and I have the bike wired to start now the black wire on the regulator is producing the same amount of volts as the battery it's like the power is back feeding could that stator do this or could I try hooking up the r/r back words would it hurt anything... The bike does not have to be running for the black wire to produce power
- Kz twin
06 May 2012 15:26
Can anyone tell me what I'm doing wrong on my regulator I have 4 wires two yellows a black and a red/white does anyone know where those go I think the yellows go to the stator but the others I'm lost if I can get this figure out I can charge my battery I would be very happy of someone could help
- MFolks
06 May 2012 15:52
The YELLOW wires are the alternator output,they should go to the regulator/rectifier. The RED/White should be connected to the battery to charge it. I'd think the BLACK wire will connect to a good ground.
- Kz twin
06 May 2012 15:54
Now what happens when the black wire is producing power
- MFolks
06 May 2012 16:57
The battery must receive Negative(-)voltage when the charging system is working properly.Positive(+) voltage is sent from the battery to the bikes electrical system demands. The regulator/rectifier produces both Negative and Positive voltage from the Alternating current from the bikes Alternator(or A.C. Generator).
- Kz twin
06 May 2012 17:07
I have a new regulator lol and every time I hook up the regulator red white wire to poss. And black to neg. the black wire smokes and gets really warm so I un hook it so the regulator don't mess up I'm compleatly lost my old one did the same thing
06 May 2012 18:03
Just to confirm -- would double-check that the battery isn't connected backwards.
- Kz twin
06 May 2012 18:18
Well after I studied how to hook up a battery lol j/k. The regulator is now working no issues y I don't no but thanks to all who helped
- MFolks
06 May 2012 18:19
Has the battery health been checked? Fully charged,load tested? Specific gravity good when fully charged?(it's a means of testing the fluid in each cell by using a simple glass tube to collect the electrolite(the fluid) and see how many special balls are floating).
- Kz twin
11 May 2012 02:50
That I couldn't tell u it was a brand new battery I took it out tested the load it was good and put it in but it's charging now
