main fuse getting hot
- MattBlack
Re: main fuse getting hot
01 Jun 2006 13:22
So is converting to blade style fuses jsut as simple as replacing them with the same size fuse and holder in a blade style?
- The Milkman
01 Jun 2006 14:52
You can either use seperate holders and solder them onto the original wires or get a fuse block for them, most if not all auto parts stores will have a block and then just attach the wires to the block. The block looks much better though.
Ride safe,
Les
Ride safe,
Les
- 1977kz
02 Jun 2006 15:20
The main fuse connection was bad. resoldered it now it's fine.I would like to see some pics of the conversation to blade fuse's
- 1977kz
02 Jun 2006 15:22
- 1977kz
02 Jun 2006 15:22
