Dumb question about rear turn signals
- Serpent7
- Nothing professionally, only for fun...
Thanks!
19 Audi Q5
14 Volkswagen Touareg X
97 Honda Shadow Spirit
79 Kawasaki KZ1000 st
79 Volkswagen Transporter
73 Volkswagen Thing
- MFolks
- Thank you received: 540
Color Codes On Most Kawasaki’s (written for 1980’s bikes)
HEADLIGHT
RED with BLACK stripe, High Beam.
RED with YELLOW stripe, Low Beam.
BLACK with YELLOW stripe, the ground circuit.
BRAKE/TAIL LIGHT Can be an # 1157 dual filament bulb
RED, Running or Tail Light.
BLUE,(sometimes with a Red stripe) Brake Light Circuit.
LEFT FRONT TURN SIGNAL Can be an #1157 dual filament bulb
GREEN, Left front turn signal circuit.
BLUE, Left front running light circuit.
RIGHT FRONT TURN SIGNAL Can be an # 1157 dual filament bulb
GREY, Right front turn signal circuit.
BLUE, Right front running light circuit.
LEFT REAR TURN SIGNAL Can be an #1156 single filament bulb
GREEN, Left rear turn signal circuit.
RIGHT REAR TURN SIGNAL Can be an #1156 single filament bulb
GREY, Right rear turn signal circuit.
- bountyhunter
- Thank you received: 337
- Serpent7
19 Audi Q5
73 Volkswagen Thing
- Serpent7
Please advise...
19 Audi Q5
73 Volkswagen Thing
- Grumpy Ole Artist
- Eschew Obfuscation!
- Thank you received: 62
1978 KZ650 B2
Former rides...1976 CB360T, 1985 Shadow 700, 1985 GPZ750Turbo
- bountyhunter
If they are single filament, they are turn signal only. If they come on as running lights, they are connected as running light which is wrong. They have to connect to the turn signal power line. On the stock bike, the fronts are dual filament for running/turn and rears were single filament for TS only.Serpent7 wrote: Ok, so I got in a set of metal ones (2 wire) and have connected them, they come on (like running lights) but don't blink when I click the turn signal up, or down? Any ideas where to/how to start trouble shooting them?
Please advise...
- Serpent7
Grumpy Ole Artist wrote: Q; Did the fronts blink before you hooked up the new rears? A1; If yes, Did you refer to mfolks color codes/your FSM diagram? (Something could be crossed) A2; If no, I would look at the flasher(s). Make ABSOLUTELY sure that you have a good clean ground at each corner too...Good luck! I hate chasing electrical problems! LOL!
I never tried the forks only (blinking, or not)… My rear lights are the dual filament though so that is an issue. I do however, I do want running lights, and turn signals in the rear.
19 Audi Q5
73 Volkswagen Thing
- Serpent7
Please advise...
Haha! Well I guess that is one of my problems… I have the dual filament in the rears also. So my rears, as well as my turn signals are running lights as well as turn signals.
A crazy thought… Can I just run my rear lights with my front lights? In theory, that would make them as running lights, as well as turn signals provided my fronts work, right?
19 Audi Q5
73 Volkswagen Thing
- MFolks
- Grumpy Ole Artist
I would get the correct parts...Got a multimeter? They can be pretty handy! Good luck!
edited for additional info:
Ahh, gotcha! I suppose one COULD run jumpers to the front running lights, giving you "rear running lights", but that might detract from the visibility/discernability of the brake light...I'm sure someone more knowledgeable than myself will chime in as to the potential pros & cons!
1978 KZ650 B2
- bountyhunter
CORRECT. Which is why I sprayed mine red so I could have running lights/turn signals in the rear and they also act as brake lights. But they do have to be red.MFolks wrote: Check with your state police or license dept. Some states do not allow amber(yellow) running lights in the rear as this could get you a ticket.
There are red lenses available from cop bikes I have seen them on ebay.
