Sudden loss of power
  • XL777
  • XL777's Avatar Topic Author
Re: Sudden loss of power
24 Mar 2012 23:56
#511776
The wire for the tach wraps around the plug wire not the coil sorry.
I'd hope the valves would be ok I just did them less then 600 km ago. However I did do and entire top end head rebuild and bore so some settling could have occurred. I understand poor valve clearance would cause power issues but how would it cause total power failure?
2012 Triumph Bonneville SE black
1978 KZ1000 B2 LTD
Fresh top end rebuild
Rebuilt head
Wiseco 1015 pistons
Dyna s
Green Dyna coils
Wired george mod
It is easier to say what I haven't replaced then what I have.
I must love this cruel mistress since she hates me
  • mark1122
  • mark1122's Avatar
  • Keep twisting it
25 Mar 2012 08:34
#511824
if valve clearance is too tight, the valve will stay open a bit when it gets hot(expansion), thus loosing compresion, and power.
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
  • XL777
25 Mar 2012 15:52 - 25 Mar 2012 16:33
#511893
Thank you OMR for your info through Pm. I have found a possible cause.
First I measured the plug wire, coils, and primary wires.
grey Dyna 8mm suppression wire
1-5.2 ohms
4-4.8 ohms
Primary wire 0.4 ohms - 3 exposed breaks in the wire jacket!!! kinked and aged miss this last year when I did my electrical inspection or recent. - Repaired reads 0.4 ohms
1/4 coil readings
Primary -3 ohm
Secondary - 0 looks like it is dead
2-4.5 ohms
3-4.8 ohms
Primary wire 0.7 ohms
2/3 coil readings
Primary - 3.5 ohms
Secondary - 13.7K ohms
Looks like a short and bad coil is the issue. Why would this only show up when warm? I was getting spark from all the plugs???
I should add I have the Wired George relay mod as well. The Dyna S is running off the yellow/red wire relay #86 from the kill switch vs the #87 relay powering the coils. Don't know why I did this but power is power so it shouldnt matter right? It worked ha!
Something to note I believe all these years I have had my Dyna S hooked up backwards and WRONG!! I found OMR's Dyna write up and I had my 1/4 black primary wire connected to the Dyna 2/3 black wire! FING dyna manual! How is this even possible I have been riding this bike like this for a few years?
1978 KZ1000 B2 LTD
Rebuilt head
Wiseco 1015 pistons
Dyna s
Green Dyna coils
Wired george mod
Last edit: 25 Mar 2012 16:33 by XL777.
  • XL777
27 Mar 2012 01:28
#512245
I did some more checking tonight and found a few oddities
1. Both coils produce a solid spark?
2. Coil 1/4 the bad one has visual cracks along the mounting bracket and cracks around the primary contact!! possibly from a short in the wire I found. That may explain why when it warms up I lose power.
My spark plug tips appear different as well
1-Brown/yellow deposits
4-Brown with black tip
2-black with grey tips
3-black with grey tips
Thirdly, is it possible my Dyna S was made backwards? (Friday special heh) As I mentioned in the last post I had thought I had the lead backwards as I marked them when I took it apart. This may not be the case. I tested it by connecting the leads up as written in OMRs post. White with black heat shrink goes to 1-4, black with green heat shrink goes to 2-3. Well using a test light my F mark reads 2-3 on my 1-4 coil....... reverse them and it works fine and how I was using it...
1978 KZ1000 B2 LTD
Rebuilt head
Wiseco 1015 pistons
Dyna s
Green Dyna coils
Wired george mod
27 Mar 2012 10:05
#512269
Perhaps rotor installed 180° off.
Good Fortune! :)
  • martin_csr
  • martin_csr's Avatar
Re: -
27 Mar 2012 11:31 - 21 Feb 2013 15:33
#512282
Last edit: 21 Feb 2013 15:33 by martin_csr.
  • XL777
30 Mar 2012 00:51
#512928
Patton wrote: Perhaps rotor installed 180° off.
Good Fortune! :)
Well that would be logical but according to the diagram the plate is mounted with the 1/4 in the back and 2/3 forward. As the white lead comes off the 1/4 and that lead is mounted on the plate to the rear it should be setup correct.
Funny thing is I just switched the the leads and it works fine ha.
Now I just have to wait for new coils and test this all again.
1978 KZ1000 B2 LTD
Rebuilt head
Wiseco 1015 pistons
Dyna s
Green Dyna coils
Wired george mod
  • XL777
30 Mar 2012 17:08
#513055
So I get the newbie award this time YES the rotor was installed 180 off haha thanks Patton please pass me the stupid sign.
Coils are here hope to have it all together tonight. Weather is getting better and the vintage bike show is this weekend so I'm hoping to ride it there!
1978 KZ1000 B2 LTD
Rebuilt head
Wiseco 1015 pistons
Dyna s
Green Dyna coils
Wired george mod
  • XL777
31 Mar 2012 00:26
#513101
Oh ya the beast is alive. Fired up and ran strong. :cheer:
1978 KZ1000 B2 LTD
Rebuilt head
Wiseco 1015 pistons
Dyna s
Green Dyna coils
Wired george mod
  • Old Man Rock
  • Old Man Rock's Avatar
31 Mar 2012 09:34
#513135
B) .... Ran strong must be an understatement for she must have all kinds of power compared to how she was configured... :laugh: Excellent! ;)
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
