- Thank you received: 6
Does this look right?
- badrhino
29 Nov 2011 17:19 - 29 Nov 2011 17:19 #490680
by badrhino
1980 KZ1000 with a 1982 KZ1000J motor with 1100 pistons and heads, Vance & Hines, 29MM Smooth Bores, Work in Progress
Franken Z!
Does this look right? was created by badrhino
I had to replace the speedometer drive and apparently didn't take notice of the gap between the drive and the wheel center hub cap when removing the original. Is this big of gap normal?
Franken Z!
Last edit: 29 Nov 2011 17:19 by badrhino.
- bountyhunter
- Thank you received: 337
29 Nov 2011 20:09 #490701
by bountyhunter
Replied by bountyhunter on topic Does this look right?
I know there is some kind of drive notch or slot that has to mate. make sure it's in right.
- badrhino
29 Nov 2011 22:01 - 29 Nov 2011 22:02 #490734
by badrhino
Franken Z!
Replied by badrhino on topic Does this look right?
Darn nobody can go and look at their front wheel and tell me if there is that big of gap on their bikes? By the way it is a 1980 KZ1000
Franken Z!
Last edit: 29 Nov 2011 22:02 by badrhino.
- P21
- Thank you received: 34
29 Nov 2011 23:06 #490754
by P21
not much of help it looks differant than mine (2002)
Kawasaki KZ 1000 Police (2002) P21
Replied by P21 on topic Does this look right?
Attachment speedo008.jpg not found
- Rainman
- and a little Kaw shall lead them
- Thank you received: 75
29 Nov 2011 23:19 - 29 Nov 2011 23:20 #490760
by Rainman
80 KZ750 H1 - the Kaw calf
79 KZ750 Twin - Miss Nov 2008 KZR calander
79 KZ750 Twin parts bike
78 KZ650 C2 Parts Bike
75 KZ400 Wife's old bike sold
81 KZ440 A2 LTD Wife's new bike
84 Honda 450 Rebel Wife's newest bike
Jim
Quincy,IL
Replied by Rainman on topic Does this look right?
Jim
Quincy,IL
Last edit: 29 Nov 2011 23:20 by Rainman.
- TeK9iNe
- What did you do!?!
- Thank you received: 28
29 Nov 2011 23:21 #490761
by TeK9iNe
Maybe this will help... you didnt specify model type kz1000- A4, B4, C3, D3, E2, or G1 ??? All 80 yr models.
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
Replied by TeK9iNe on topic Does this look right?
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- badrhino
30 Nov 2011 01:31 #490780
by badrhino
Franken Z!
Sorry it is a B4.
Franken Z!
- RonKZ650
- Thank you received: 240
30 Nov 2011 01:53 - 30 Nov 2011 01:54 #490782
by RonKZ650
Replied by RonKZ650 on topic Does this look right?
I don't think it's right, but only takes 30 seconds to put the axle through and begin to tighten the axle nuts. If any resistance to easy roll of the wheel by starting to tighten the axle, the tangs in the drive are not aligned correctly with the cut outs in the wheel. That's what it looks like, the drive is not aligned correctly but give it a go with the axle to see.
Last edit: 30 Nov 2011 01:54 by RonKZ650.
- monkfishing
11 Dec 2011 12:38 #492649
by monkfishing
Replied by monkfishing on topic Does this look right?
just looked at mine a 1980ltd 1000 there is about a 1/16 gap between drive & hub.
- badrhino
23 Feb 2012 03:35 - 23 Feb 2012 03:37 #505846
by badrhino
Franken Z!
oops double post!
Franken Z!
Last edit: 23 Feb 2012 03:37 by badrhino.
- badrhino
23 Feb 2012 03:35 #505847
by badrhino
Franken Z!
Well I assembled the front wheel and put it on the bike. Tightened everything up and it still looks like there is a good sized gap between the wheel hub cover and the speedometer drive unit.
Can anyone else with a 1980 KZ1000 or similar set-up tell me if this looks right?
Franken Z!
