hot signal bulbs
  • mark1122
  • mark1122's Avatar Topic Author
  • Keep twisting it
Re: hot signal bulbs
13 Aug 2011 15:17
#468815
if i switch to LED turn signals will i need 1 resistor for each side ?
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
  • Motor Head
  • Motor Head's Avatar
14 Aug 2011 09:48 - 14 Aug 2011 09:48
#468989
If you get the right flasher, Electronic fo LED's, then probably not. If you have the 2 filament bulbs now, where you have a running light and turn in one housing, get the LED replacement bulb that has both as well. You have probably seen this web site linked in before, but here it is again, Bookmark it. www.superbrightleds.com/
They will have all of it from one supplier.
Last edit: 14 Aug 2011 09:48 by Motor Head.
