Regulator rectifier wiring
  • wcrider62
  • wcrider62's Avatar
Re: Regulator rectifier wiring
21 Jan 2012 15:15
#499247
Attachment kzwiring.jpg not found
hey patten. trying to figure where to conect the brown one .cinda confused with this wiring design can ya help ?
1982 kz1100 spectre D1
The following user(s) said Thank You: element303
  • wcrider62
22 Jan 2012 13:30
#499401
ok I think I got it figured this time lol
  • element303
  • element303's Avatar
23 Aug 2014 07:54
#644873
Ok.. I just read through all this because I opened another topic with a similar issue and I don't understand the wiring diagram, because i see a few cables I don't have. I don't have any connectors anymore so I will connect it straight back to the cables how it is now. I have a 750 LTD and I got 6 cables in total coming out of the regulator. The 3 yellow ones I read don't matter in which order they go to the 3 yellow ones coming from the engine. The black one obviously is ground, the brown one goes to the tail light and what about the red/white one? is that one going directly to the battery + to charge it? I just want to make sure I do it right and stop frying the coils and ignition cause im starting to run out of money after buying 8 coils already..... Thank you guys
Custom 1981 KZ750 rebuild project
[img
  • element303
23 Aug 2014 08:00
#644874
ok never mind. i just saw this one and new its clear. thank you!
[img
