Engine problem, Where to get cheap parts?
  • otakar
  • otakar's Avatar
Re: Engine problem, Where to get cheap parts?
04 May 2011 16:59 - 04 May 2011 17:01
#448877
No eBay APP ID and/or Cert ID defined in Kunena configurationYou will require a fly-wheel puller. It is a bolt that screws into the crank and pushes the wheel off. It is an 18x1.4mm puller. Z1Enterprises will also have them in stock if not than here is one.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
Last edit: 04 May 2011 17:01 by otakar.
  • gnstalodz
  • gnstalodz's Avatar Topic Author
04 May 2011 17:15
#448882
I have a puller and I heard you can use an existing bolt on the bike to put in there and use a hammer, flat head screwdriver, and some care. I'm more worried about this flywheel bolt I cant get it off haha
81 440 ltd
  • otakar
  • otakar's Avatar
04 May 2011 17:17
#448884
Use an air impact wrench for both. That is about the only way to get them off.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
  • gnstalodz
04 May 2011 17:27
#448886
Ok, but this flywheel bolt if Clockwise to remove right?
81 440 ltd
  • otakar
  • otakar's Avatar
04 May 2011 17:30 - 04 May 2011 17:31
#448887
It should be a standard Rt. hand bolt. Righty-Tighty, Lefty-Loosey ;) If it was anything but, it would be mentioned in the FSM.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Last edit: 04 May 2011 17:31 by otakar.
  • gnstalodz
04 May 2011 17:47
#448890
I was afraid of that lol
81 440 ltd
  • otakar
  • otakar's Avatar
04 May 2011 19:26
#448901
You were afraid of that, --- because
You have already put the torque of death on it attempting to loosen it in the clockwise direction? :pinch: :blink: :huh:
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
  • gnstalodz
04 May 2011 23:48
#448957
lol no the opposite. I put the death turn on it going counterclock and it still didnt come off haha. Any tricks?
81 440 ltd
05 May 2011 00:37
#448972
gnstalodz wrote: ...Now I just need to search how to remove this darn flywheel
Click > www.kzrider.com/forum/2-engine/399151-kz-porn :woohoo:
Good Fortune! :)
  • gnstalodz
05 May 2011 17:48
#449074
www.z1enterprises.com/detail.aspx?ID=4361
I guess there is a small diff in the rebuild kits. One for smaller one for larger CCs
81 440 ltd
