1977 kz650 stator
  • mjwriz
  • mjwriz's Avatar Topic Author
Re: 1977 kz650 stator
02 May 2006 07:17
#44427
i know that it's the stator because the mechanic that i took it to said it was weak and only putting out 11.8 when it should be putting out about 13.
  • Shoe48
  • Shoe48's Avatar
  • Live each day as it is your last
02 May 2006 07:31
#44432
I have a stator and maybe a regulator too .. U2U me if interested ,, I can save you some money :)
  • loudhvx
  • loudhvx's Avatar
02 May 2006 07:40
#44435
Well, I hope he was a really good mechanic. Many mechanics wouldn't have a clue on your alternator. I'm not trying to bad-mouth your mechanic or anything, I'm just speaking from experience.
A stator test done properly won't usually come up with a number like 11.8. When you isolate the stator and test it, the output will be more like 100 volts. You achieve this by bypassing the regulator and open-ending the rectifier as Kit did in his thread. If you don't get the 75~100 volts, then you have to verify the field-coil by detecting the magnetism as Kit also did.
ooops, here's the link to Kit's thread:
kzrider.com/component/option,com_joomlab...ew/id,35581/catid,4/
Post edited by: loudhvx, at: 2006/05/02 10:48
  • steell
  • steell's Avatar
02 May 2006 09:36
#44466
I just checked the 650 manual to get the actual numbers on the stator test, and it specifies "about 75V at 4000 rpm", loudhvx's statement that it should be 75-100V is right.
If you search the board, you will find regulator/rectifier and ignitor designs by loudhvx, he is a professional electronics guy, and an expert on these charging systems.
I argue with everyone, except loudhvx on electronics stuff :laugh: :laugh:
Btw, I checked the manual for charging system output at the battery for the KZ650.
Reading @ 4000 rpm. about 14.5V
If the reading is more than 16V, the regulator/rectifier is defective, and should be replaced with a new one.
If the reading is less than 14V, check the dynamo output and regulator/rectifier to determine which part is defective
Post edited by: steell, at: 2006/05/02 12:45
  • clone5
  • clone5's Avatar
26 May 2007 01:45
#143591
mjwriz wrote:
somebody told me that there is 2 stators in a 1977 kawasaki kz650 b1, an inner one and an outer one. is that true?
That's right. The inner one was on the B and C models. I have an outer cover for sale in the classifieds " HERE " if you're interested. New/Old stock very good condition at quite a good price. I bought the wrong one :(
  • RonKZ650
  • RonKZ650's Avatar
26 May 2007 14:53
#143692
Here's a 77 stator. Like the other guys said more likely the regulator or rectifier is bad.
