KZ1000 Ricks rec/reg
  • 55fbomb
  • 55fbomb's Avatar Topic Author
Re: KZ1000 Ricks rec/reg
12 Mar 2011 09:34
#437352
Yes, i have a red/pink wire a yellow wire and a blue wire in the conector along with the oil pressure and nuetral indicator wires. my instructions say to just hook the 3 yellow wires to the stator wires in no particular order, just wanted to pass it by you guys and see what you all thought.
1974 CB750
1975 CB750
197? CB750 mutt
1977 KZ1000
  • Old Man Rock
  • Old Man Rock's Avatar
12 Mar 2011 10:17
#437365
It won't matter which yellow for identical circuits in the OEM builds (rectifier/regulator) as depicted in those images...
If your using some other regulator unknown to me anyways... Mfolks may have additional info...
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
  • DoubleDub
  • DoubleDub's Avatar
12 Mar 2011 10:18
#437366
Sounds like you should be fine. If they say order doesn't matter, I don't see why it would be an issue.
