Electrical Newbie
- calvin17d
Re: Electrical Newbie
04 Mar 2011 07:58
Old Man Rock wrote:
OMR!
I must say, that this is the kind of advice I hope to find when joining these technical forums. Very thoughtfully spelled out, with no assumptions made as to my knowledge of wiring. Very helpful on checking the ignition switch which my clymer does not cover. Does FSM have specifics such as this? Although the engine did turn over, i did see a drop across the brown solder joint on the ignition when switched to on?
With a volt meter set for resistance measurements.
Insure both frame and engine is properly grounded
* Black meter probe on battery ground.
* Red probe on engine/bare metal frame.
With a volt meter set for Vdc measurements.
NOTE: AS you go through your cable harness, connections, measurements, you may want to turn your ignition switch on and off until ready to measure so as to not drain the battery.
* Measure battery voltage, if charged, should be ~ 12-12.5Vdc. (I'll just use +12Vdc for discussion)...
* From Battery (+) terminal follow conductor to fuse, measure for ~ +12Vdc (Battery voltage) on both sides of fuse holder.
* Follow conductor all the way through to ignition switch, for +12Vdc.
* Turn ignition switch to on position.
* Measure for 12Vdc on Brown conductor. If missing, or under -1Vdc off battery voltage then faulty ignition switch. You can try cleaning contacts but for $20, get a new one @ Z1.
* Follow brown conductor through the harness connection... Good spot for oxidized connector pins, clean pins with Emory cloth...
* With the emergency stop switch in the on position, you should now have 12Vdc on the orange conductor that feed your coils and starter button.
* The starter button switch, press and switch 12Vdc to the starter solenoid...
I think you get how this works... good luck...
OMR
OMR!
1976 Kz900 A4
04 Mar 2011 08:08
Before you completely disassemble the electrical system try it again but pull in the clutch lever this time.
- tinlizzie37
04 Mar 2011 10:36
Yes a factory manual has the methods to check all your electrical items and the values they are supposed to have. Bob
Bob KZ 650 E1, En 450
- Old Man Rock
04 Mar 2011 14:43
Speaking of which...
OEM Service Manual for the Z1 (900) 98% the same as the 1976/77 KZ900...
Oh, did I mention... FREE!
kzrider.com/index.php?option=com_docman&...d&gid=434&Itemid=108
As for the voltage drop, how much?
Now keep in mind, there can be a significant drop (1-2Vdc) with the engine not running due to load...
You'll also find this in the linked manual fro checking the Dynamo, rectifier and regulator circuits....
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- Old Man Rock
04 Mar 2011 14:44
coil testing... Not a 100% test grant you but if dead shorted or open, yeah it works well enough....
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- calvin17d
04 Mar 2011 19:07 - 04 Mar 2011 19:10
this forum just keeps getting better. As stated, got the issue resolved. Here are a couple of videos of initial start up and one from the break-in.
picasaweb.google.com/cdedeker/20110304?feat=directlink
1976 Kz900 A4
Last edit: 04 Mar 2011 19:10 by calvin17d.
- TeK9iNe
- What did you do!?!
05 Mar 2011 08:30 - 05 Mar 2011 08:33
Right on man.
PS. OMR, tisk tisk - a batt that is resting at 12V is in need of charging
SOC (State of Charge) closely correlates to available current AMPS.
Batteries are considered to be fully charged when after resting a few hours - they are at 12.5VDC or better. Basically being able to delivery 90% max current or better.
HEADS UP! :laugh:
Peace.
HEADS UP! :laugh:
Peace.
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
Last edit: 05 Mar 2011 08:33 by TeK9iNe.
