motor died on highway
- MFolks
Re: motor died on highway
13 Jan 2011 16:06
Here's a wiring diagram that should help:
www.cyclepsycho.com/kz1000p/kz1000p.html
14 Jan 2011 02:40
If not already done, would check and assure integrity of the ground connection where negative battery cable attaches to rear of engine.
- tonyc
14 Jan 2011 08:55
hi tony here i had to put in new rollers and springs in the starter clutch today as i was not getting any sparks had to take of the fly wheel the starter motor was turning but the fly wheel wasn't so thats was why the new rollers and springs now just to put ever thing back on
- dejavoodo41
14 Jan 2011 12:03
I had a problem with my bike dying on the highway and when I'd pull over it would fire right back up. The problem turned out to be the ignition switch. The vibrations from running 80 on the freeway were causing the contact to open and cause the bike to shut off. I thought it was weird that it never happened in town just when I was bombing down the freeway. I went to JP cycles and bought a universal ignition switch and haven't had any problems since.
1977 KZ1000A With 1980 KZ1000A MKII engine, Wiseco 1105 kit, Dyna S Ignition, 3 Ohm Dyna Coils, Cams, Mikuni RS34 Carbs, Vance and Hines Pro Pipe with Comp Baffle
New Smyrna Beach, FL
- merslinger
29 Jan 2011 19:12
thanks for all the help after reading and following way to many wires and wiring diagrams i found the faulty connection on the wire running from the battery to a 30a fuse then straight to the many fuse hub. no blown fuses but i have found that i person i recently purchased the bike from wired everything himself. not to well. i have found why he couldnt get the brake light to activate with front brake only rear. looks like i have a lot more wires to follow and fix but thanks for the help. learned alot about my kz.
1993 kz1000
