Spark Plugs and Cyl order
- MFolks
Re: Spark Plugs and Cyl order
22 Nov 2010 15:40
I've read/heard that a business card thickness will get the point gap close enough for the engine to run.
22 Nov 2010 20:32 - 22 Nov 2010 20:33
Reminder -- Should dress/clean contacts and set gap before adjusting timing.
Last edit: 22 Nov 2010 20:33 by Patton.
22 Nov 2010 20:45 - 22 Nov 2010 20:47
marcuch wrote:
For instance, 1/4 coil on large Kaw fours typically mounts on left (shift lever) side of bike, with 2/3 coil mounted on right (brake pedal) side of bike.
KZ650 mounting is opposite.
Regardless of its mounting position, whichever coil receives signal from left-hand points/module/pickup is supposed to fire outside plugs 1&4.
And whichever coil receives signal from right-hand points/module/pickup is supposed to fire inside plugs 2&3.
Further confusion may be contributed by an erroneous or inconclusive wiring diagram.
Confusion in researching the matter might result from different stock coil mounting positions.The more I read the more I see conflicting answers....
Last edit: 22 Nov 2010 20:47 by Patton.
- Becker
- The Doctor Will Rise Again
29 Nov 2010 22:21
What were they thinking when they changed everything around on the KZ650. That just doesn't make sense.
Anyway, what are you using to time and gap the points. Just curious.
78 KZ750B3
79 KZ400 LTD
78 KZ650C2
79 KZ650C3
78 KZ650B2A
80 KZ650F1
80 KZ650E1
81 CB750K Super Sport
79 KZ400 LTD
78 KZ650C2
79 KZ650C3
78 KZ650B2A
80 KZ650F1
80 KZ650E1
- Visage
14 Jan 2011 21:38
Ok guys, Same problem here. After a 5 year complete restoration I am ready to fire the bike up. I understand one coil fires cylinders 1 & 4 and one coil fires cylinders 2 & 3, but on a stock coil which plug wires go to which cylinder, or does it even matter? Do cylinders fire in pairs?
Please help.
Ray :S
Please help.
Ray :S
- MFolks
14 Jan 2011 21:56
No, the ignition coil ports(where the sparkplug wires go)fires both at the same time, so as long as the correct coil goes to the correct sparkplug, it should work.
Use which ever port to reach the sparkplugs.
15 Jan 2011 06:19
Please help.
Ray :S
15 Jan 2011 06:23
Z1 ign coil to outside plugs is located on left shift lever side of bike , and coil to inside plugs is located on right foot brake side of bike.
- loudhvx
15 Jan 2011 11:33 - 15 Jan 2011 11:35
Just so it's all in one thread, the 550 and 750-fours are setup like the 650: 1,4 coil on the right, 2,3 coil on the left. (As Patton said, it is opposite of the big KZ-fours.)
And, (as has been established,) on all motors (big or small KZ-fours), the points or pickups near the front of the motor are for 2,3, and the rear points or pickups are for 1,4.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
Last edit: 15 Jan 2011 11:35 by loudhvx.
- Visage
15 Jan 2011 23:05
Hi Guys,
Maybe I was unclear. Yes I understand the left coil goes to cylinders 1 & 4 (black wire) and the right coil goes to 2 & 3 (green), but my questions are 1) Do cylinders 1 & 4 fire at the same time, do cylinders 2&3 fire at the same? in other words is there two power strokes at a time? Also, if they do not fire at the same time, how can you tell which plug wire goes to which cylinder? For example, on the coil that goes to cylinders 1 & 4 (outsides) there are two plug wires, but which plug wire will go to 1 and which will go to 4?
Thanks again guys,
Ray
Thanks again guys,
Ray
- MFolks
15 Jan 2011 23:39
On these bikes there is a wasted spark, that is a plug will fire on a exhaust stroke.
A 4 cylinder 4 stroke will have at least one cylinder producing power at any given time.
