Adding a 12V power supply
  • MFolks
  • MFolks's Avatar
Re: Adding a 12V power supply
31 Oct 2010 14:31
#410120
  • otakar
  • otakar's Avatar
31 Oct 2010 15:15
#410127
This is what I have on mine. I bought it at Radio Shack. I use it to power my GPS, heated gloves, Charge cell phone, and so on. I keep a plastic cap on it to keep out junk and rain.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
  • otakar
  • otakar's Avatar
31 Oct 2010 15:19 - 31 Oct 2010 15:19
#410128
I keep a small bungy cord on it to hold in anything I plug in while riding. I find that the vibration of the engine pushes out any connection I put in.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Last edit: 31 Oct 2010 15:19 by otakar.
  • otakar
  • otakar's Avatar
31 Oct 2010 15:20
#410129
I have had this on my bike for about three years now.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
  • otakar
  • otakar's Avatar
31 Oct 2010 15:21
#410131
When not in use it hides right next to the ignition lock very nicely.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
  • JMKZHI
  • JMKZHI's Avatar Topic Author
20 Nov 2010 10:48 - 08 Oct 2011 18:00
#413568
The setup is going to be a slime air pump, bikemaster 12V power socket, & a homemade pigtail mounted to the battery.
Last edit: 08 Oct 2011 18:00 by JMKZHI.
  • JMKZHI
20 Nov 2010 10:49 - 08 Oct 2011 18:06
#413569
The one from CycleGear is supposed to be water proof and has a black wire & a green wire.
I can't seem to make out what gauge the wire is: it's either AWG 16 or AWG 18.
So I guess I'll make up an AWG 16 pigtail for it.
Shall I assume the green wire is the negative (-) & the black wire is positive (+).?
Last edit: 08 Oct 2011 18:06 by JMKZHI.
  • loudhvx
  • loudhvx's Avatar
20 Nov 2010 21:06
#413622
I wouldn't assume. Probably have to wait till you get it.
Honda uses black as positive and green as ground.
Everyone else seems to use black as ground.
In most DC electronics, red is positive and black is ground.
With green and black wiring... hard to guess.
  • JMKZHI
21 Nov 2010 06:29 - 21 Nov 2010 07:40
#413634
I have it already - see photos above.
I guess the positive would be the center contact of the socket?
But how do I figure out which one is which? :blush:
Edit: I rigged the socket to the bike & using a 12V test light proved that the black wire is connected to the center electrode at the base of the socket.
So the black wire would be positive (+).? ... Correct?
Last edit: 21 Nov 2010 07:40 by JMKZHI.
  • otakar
  • otakar's Avatar
21 Nov 2010 08:30
#413641
It is obvious just looking at the picture which wire is positive and negative, and if you can't tell just by looking at the plugs on the wires than put a meter to the wires and the contacts in the accessory.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
