Obscure 77 kz1000 Tach Question.
  • Galactica
  • Galactica's Avatar Topic Author
12 Sep 2010 16:24
#398089
So I drove to Montana from Vancouver BC on the Labour Day weekend to pick up a 77 kz1000. I took some pictures to show an acquaintance who knows a bit about 77 kz1000's. He noted that the tach on my bike has a redline of 9000 rpm. He says that the 1000's have a redline of 8500 rpm.
Th build date on my bike is 09/76, and the serial # is KZT00A-005231. I'm reasonably certain that the tach is original, and not a replacement from a kz900.
Any thoughts from anyone?
Thanks in advance,
Ross
77KZ1000
76 KZ900
  • taildragger1197
  • taildragger1197's Avatar
Re: Obscure 77 kz1000 Tach Question.
12 Sep 2010 16:45
#398093
I am not an expert(several here come close) but I believe only the KZ-1000LTD model had the 8500rpm tach. The KZ1000 had the 9000 rpm tach. I am sure someone else will chime in with the info you need.
Union City, Tennessee
1979 KZ1000 LTD B3
1979 KZ1000(1260)LTD S/G Pro ET
1993 ZX11 D1 Ninja
  • PLUMMEN
  • PLUMMEN's Avatar
12 Sep 2010 16:52
#398094
78 had a 9000rpm red line,dont have a 77 handy to look at though.guessing probably the same as 78 B)
  • Galactica
12 Sep 2010 16:55
#398095
Just wondering why only the LTD would have 8500 rpm redline and the kz 9000?
77KZ1000
76 KZ900
  • taildragger1197
12 Sep 2010 16:58 - 12 Sep 2010 17:08
#398096
Different overall gear ratio on the LTD cruisers.
4.64(KZ/LTD) vs. 4.92(KZ)
I just checked and the '77KZ ratio was the same as the '79LTD(the ones I have always owned) ratio so you may have to do some more checking. Ma Kaw did lots of things we don't really understand.
1979 KZ1000 LTD B3
1993 ZX11 D1 Ninja
Last edit: 12 Sep 2010 17:08 by taildragger1197. Reason: second guessing myself
  • Galactica
12 Sep 2010 17:02
#398099
I think that explains it. I'll check, but I believe my friend's bike is an LTD.
Thanks guys.
77KZ1000
76 KZ900
  • donthekawguy
  • donthekawguy's Avatar
12 Sep 2010 17:16
#398102
My 77 is 99% stock and it has a 9K redline.
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1965 Suzuki Hillbilly
1964 Yamaha 125
  • Motor Head
  • Motor Head's Avatar
12 Sep 2010 17:21
#398104
For the KZ, Possibly the cams had more lift, with a higher rate valve spring, than the LTD? Surely this info is out there from a lot of guys. Some FSM's to compare?
  • Gman
  • Gman's Avatar
13 Sep 2010 17:07
#398342
My original '78 KZ1000 A-2 has a 8500 tach. In the owners manual some of the tach pics show a 8500 tach, other pics show a 9000 tach. I suspect maybe they changed mid-year. Hard to say.
1978 KZ1000
1965 Harly Electra Glide
2002 Gold Wing
1974 Z1 900 project
  • TerryK
  • TerryK's Avatar
14 Sep 2010 18:20
#398767
I'm the second owner of my 77' (bought it in 84') so I'm positive the tach is the original 9000 rpm unit.
1977 KZ1000
GSXR swingarm and rear brake
WM6 rear Akront rim
Wiseco 1075c pistons
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
Dyan 4000 SP ignition
etc
Ontario, Canada
  • canyondancer
  • canyondancer's Avatar
14 Sep 2010 22:28
#398816
I own Z-resto and i've met a lot of folks that swear they have original gauges.....but they don't.
The KZ1000's didn't rev as high as a 900 did so Kawasaki lowered the redline 500 rpm. In other words....no matter what year it was...or when it was built,....all KZ1000's were sold with an 8.5 redline tach.
Bob
Z-Resto
  • TerryK
  • TerryK's Avatar
15 Sep 2010 07:39
#398850
Bob
Z-Resto
I bought my 1000 from the original owner. I knew him when he bought the bike and I rode with him often. The only modification he did was a V&H pipe and the bike was never crashed. Not sure if Canadian models came with 9k tachs but this one has one and it was never touched.
1977 KZ1000
WM6 rear Akront rim
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
etc
Ontario, Canada
