Plug wires and coils
  • muddytailgate
  • muddytailgate's Avatar Topic Author
Re: Plug wires and coils
06 Sep 2010 06:45 - 06 Sep 2010 06:47
#396444
110? Whaaa!? Maybe I should get after those carbs then.
1976 KZ 750b
Last edit: 06 Sep 2010 06:47 by muddytailgate.
  • Old Man Rock
  • Old Man Rock's Avatar
06 Sep 2010 07:05
#396448
Muddy... Get your electrical fixed first for you may be surprised what a new set of coils will do for that KZ...;)
New coils, plug wire set, Dyna 3 ignition with ideal voltages being supplied and you'll gain some surprising response from the old girl....
Valve clearances in spec, timing advancer operating correctly, no vacuum/exhaust leaks and you'll be doing triple digits... :woohoo: Hang on honey.... :evil:
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
  • muddytailgate
12 Sep 2010 06:52
#397970
Chased electrical/timing...couple hours.
New coils/plugs/wires....$90.
A quick frenzied cleaning of carb-jets so I can get back on the road because it was 70 degress with bluebird skies...priceless.
I blame this Lucas "Tune Up in a bottle" that the guy at parts store talked me into. I think it loosened up some 30 year old gunk and plugged up #4. This stuff will probably make a good carb dip/ cleaner.
Anyway it runs better than every as a result of "all of the above". Thanks to all for the help and the quick replies. KZrider peeps are great.
1976 KZ 750b
