signal replacement
  • johnny chop
  • johnny  chop's Avatar Topic Author
Re: signal replacement
19 Apr 2006 18:36
#40951
Here's another...
The blue wire you see is one of the wires that was used for the stock (front) signal,along with a blk/yellow which was a ground and a green(gray) wire. I'm now using only the blk/yellow on one side of the new signal & the green(gray). Is the problem becauseI'm not using the BLUE wire now??
Post edited by: johnny chop, at: 2006/04/19 21:39
Post edited by: johnny chop, at: 2006/04/20 12:33
Post edited by: johnny chop, at: 2006/04/20 12:37
  • wiredgeorge
  • wiredgeorge's Avatar
20 Apr 2006 06:58
#41076
FIRST, Have you actually looked at the bulb holder to see if it had two contacts or one contact? Second, the gray wire and the green wire are your turn signal wires. The black/yellow is the GROUND. The blue wire is a RUNNING LIGHT wire used for twin contact bulb holders.
  • johnny chop
20 Apr 2006 09:30
#41115
Yes but forgot to post it..:blush: It looks like it has two but I see only one tit,what do you think?I'm using the green (gray)? & blk/yellow wire for my turn signal. And the blue wire is not being used. But I did notice that the blue wire does go to the guage along with blk/yellow (as seen in one of the pics I posted earlier).What should this wire(blue) be connected too?
Post edited by: johnny chop, at: 2006/04/20 12:32
Post edited by: johnny chop, at: 2006/04/20 12:39
  • johnny chop
21 Apr 2006 20:27
#41572
Well it seems that I found out why my guage lights stopped working......before I say it I thought it was odd that they went out right after I installed my new signal lights.....Well anyway it was the fuse...:blush: Thanks the the people who chimed in to help.....JC
