Dang!
- wiredgeorge
Re: Dang!
25 Oct 2005 12:09
13.8 VDC should be fine and the battery should charge. Ride the bike some and get it charged via the bike's system and then try and start on a cold morning. Also, keep in mind that the oil you use in summer may not work so good in the winter... gets thickkkkkk on 30 degree mornings. Go to a bit lighter oil in mid-winter. I have pretty good luck running 15W40 year round. This in case you use 20W50 in the summer as many do in hot climes. As far as the coil re-power mod, just take your time as the job will only be as good as you do the details... no cold solder joints and use heat shrink and then wrap with electrical tape to prevent chafing (and shorts down the road). Let me know if you need any questions answered.
- fergyfer
Re: Dang!
25 Oct 2005 12:16
I just rode back to work on her and I believe she's running better than ever. You recon that bad connection might have made her run a little rough? Anyway, it was a great ride.
I'm running 10w40 in there right now. Doesn't seem to be a problem so far...
- wiredgeorge
Re: Dang!
25 Oct 2005 12:32
If the battery is good and you have almost 14 VDC at higher rpms, your bad connection was pretty much the thing that was keeping the battery from charging good.
10W40 should be fine... You can't get non-energy conserving oil in lighter weights like 10W30 or 5W30, etc anyway.
- fergyfer
Re: Dang!
26 Oct 2005 08:27
After riding to and from work yesterday, about 60 miles round trip, I put the tender on the battery and the green light came on immediately. First time that's happened so all looks good in the charging system.
