1975 KZ900 Advance curve information
  • MFolks
  • MFolks's Avatar
Re: 1975 KZ900 Advance curve information
15 Jul 2010 21:17
#382990
This will help loosen up stuck piton rings:
www.amazon.com/Yamaha-Ring-Additive-32oz...-32-00/dp/B002GUCLH2 (Yamaha Ring Free)
And here's has a combustion chamber cleaner:
Mopar Combustion Chamber Cleaner # 04318001.
  • blue75kz900
  • blue75kz900's Avatar Topic Author
15 Jul 2010 21:57 - 15 Jul 2010 21:58
#382999
Thanks for the info.
Which one do you think will get rid of most of the carbon build up the quickest.
If the recommended amount is added to one tank of gas would you notice a change after it was run through? If i looked through the sparkplug hole I would see a difference.
Thanks.
Blue 1975 KZ900
Gold 1970 Chevy Nova 427...Bike killer
Last edit: 15 Jul 2010 21:58 by blue75kz900. Reason: added a word
  • MFolks
  • MFolks's Avatar
15 Jul 2010 22:31
#383006
Probably the Mopar cleaner would remove most of the carbon buildup vs the ring free.
Some time ago, a member of the forum(can't remember who) used the Mopar cleaner and showed the result. It did a very good job of making the combustion chamber,head and valves look almost new.
  • blue75kz900
15 Jul 2010 22:37
#383007
Great, Thanks, I will try to track some down.
Blue 1975 KZ900
