GPZ1100 B2 1983 Wiring Diagram
  • Matchless
  • Matchless's Avatar Topic Author
Re: GPZ1100 B2 1983 Wiring Diagram
02 Jul 2010 08:42
#379649
9am53 wrote:
hopefully this helps
Unfortunately I cannot enlarge it enough to read any of the text. Would it be possible to upload it at a higher resolution somewhere? Or email it to me.
My apologies for all the hassle I am causing!
  • Matchless
02 Jul 2010 08:46
#379650
otakar wrote:
That is a diagram for a 1982 KZT10B. There is nowhere that I can find frame ZXT10B There was no LCD display on the tanks of Pre-83 GPz1100s. There are parts here for two or three different bikes here. Check that frame # again or post a picture of the sticker on the neck. that way the date of manufacture is visible and the frame #. The weiring diagrams were WAY different between the KZ and the ZX models. Simply just in the fact that the 81/82 had a mechanical spark advance and the 83-85 had an electronic spark advance.
I will take some photos tomorrow when there is some daylight and post it. Hopefully thay will help in identifying it.
Thanks
  • Matchless
03 Jul 2010 05:19
#379856
I have taken some photos and have confirmed that the number stamped on the steering neck is ZXT10B-000059 and the engine number is KZT10BE018xxx. Unfortunately there is no sticker of VIN plate as the frame has been resprayed.
Hopefully someone will be able to identify which wiring diagram I need.
  • Matchless
03 Jul 2010 05:24 - 03 Jul 2010 05:30
#379858
The rest of the pictures follow;
Last edit: 03 Jul 2010 05:30 by Matchless.
  • otakar
  • otakar's Avatar
03 Jul 2010 05:26
#379860
I can tell you right now that the bike has an engine from an earlier year than the frame is. If there is no sticker than it might be a factory replacement frame due to a crash. It may have been mis-stamped. I will do some more searching.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
  • Matchless
03 Jul 2010 05:29
#379861
Here are the guages:
  • Matchless
03 Jul 2010 05:31
#379862
Here is the LCD unit:
  • Matchless
03 Jul 2010 05:33
#379863
Here is the fuse and relay pack that fits the harnass:
I need the wiring diagram for this:
  • Matchless
03 Jul 2010 05:35 - 03 Jul 2010 05:35
#379864
Here is one of the igniter;
Last edit: 03 Jul 2010 05:35 by Matchless.
  • Matchless
03 Jul 2010 05:36
#379865
Finally here is one of the motor:
  • otakar
  • otakar's Avatar
03 Jul 2010 05:42 - 03 Jul 2010 05:46
#379867
Someone went to a lot of trouble to put that bike together out of at minimum three other bikes. This was NOT a performance build just due to the fact that they went threw all the trouble and mounted CV carbs, Took all of the paint off of the engine (1982 Serial#)
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Last edit: 03 Jul 2010 05:46 by otakar.
  • otakar
  • otakar's Avatar
03 Jul 2010 06:03 - 03 Jul 2010 06:14
#379869
The frame serial # is definitely a fictitious serial #. There never was a zx1100B In 83-85 the models were zx1100-A1 threw A3. In 1986 the bike went to water cooled and turned into the C1. Looking at the instruments, this is not a US/Canadian model. Because the wiring diagrams were completely different between the North American models and the "Others" PM me your email address and I will scan the diagram and email it to you. It will be for the 83 model since I do not have it for the 84-85 model. You will have to do quite a bit of rewiring with the ignition, and most likely have to change it all together. Post a picture of the pickups underneath the points cover. This will tell us what the ignition should be. You won't be able to use the ignition box at all since it must be run with the injection computer. You will have to convert either to a Dyna ignition or a non injection Kawasaki ignition. What's under the points cover will tell us what options you have. Also, since your injection computer is no longer being used, you will loose most of the displays on the instruments.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Last edit: 03 Jul 2010 06:14 by otakar.
