550 ltd reserve lighting unit
- Motor Head
Re: 550 ltd reserve lighting unit
02 Jul 2010 17:49
Well you found where the PO had Attacked the harness, are the colors the same as on your Ebay Item?
- 1981kz550ltd
- dragsta
02 Jul 2010 17:56Please Log in or Create an account to join the conversation.
- Motor Head
02 Jul 2010 17:57
Do you have a manual with a wiring diagram? If not you can temporarily hook the RLU to the harness with some alagator test wires, or similar means. Then try it, see if it helps. If you have a Kawasaki Manual it will have full diagnostic procedures for testing. There are free downloads for pdf manuals available on this site, I got 1 for my other2 bikes from here.
- 1981kz550ltd
02 Jul 2010 18:00
Yes, my clymer manual has complete wiring diagrams. i'll tinker with this and post back when i get somewhere. thanks guys!
- MFolks
02 Jul 2010 18:03
Your choice can be to splice wires together(I like using heat shrink tubing to cover the splices), or buy matching compatible connectors to mate with what you've got.
Most good auto stores sell 3m heat shrinkable spices in RED 22-18 gauge, BLUE 16-14 gauge, and YELLOW, 12-10 gauge.
I think getting both BLUE and RED splices would be the way to go if you decide not to get a connector.
A hot hair dryer might shrink the covering on the splices. if not, go to a hobby shop and buy the small heat gun used to shrink the wing film on flying models.
- 1981kz550ltd
03 Jul 2010 10:57
I've got plenty of tubing in stock, and i have always used a lighter to shrink it. it works pretty well.
- 1981kz550ltd
08 Jul 2010 12:40
Well, this was easier than I thought. I removed my gas tank because i was changing my spark plug wires and plugs. and i see a 6 pin connector just like the one on my ebay RLU. i trace it back, and there it is! the Reserve Lighting Unit was Loacated on top of my two ignition coils! who woulda thought to look there?! Anyway, my warning light is OFF!!! for once. and my New blue Halogen bulb is as bright as the sun! well, idk about that bright, but its way better! so forget all the wiring junk, but thanks anyway guys!
