charging problems
- ccentralm
Re: charging problems
25 Jul 2010 18:24
i havent any idea what my dad has and hasnt tested but ill relay all of this new info to him. one thing that he keeps going on about is that the compression could be too high after the engine is warm, making it to difficult for the starter to turn over. is there any truth to that? he also wanted to vent the valve covers as we have them blocked off right now due to the removal of the emissions control junk that came stock with the bike. i was under the impression that the bike would burn a piston if everything wasnt plugged except for the crankcase breather hole (which i have a filter on right now).
1982 Kawasaki KZ 750LTD. i wanted the big boy 1000, but there's like a billion of these 750 ltds running around. so what the hey!
- Motor Head
25 Jul 2010 18:32
Plugging off the holes at the valve cover to block the Air system is OK.
The increased compression will make the starter work harder and if the system has a weak link it will show it. But If all in correct working order I would think it should start the engine, maybe a bit of a chore if system is weak. Is yours a 2 brush or 4 brush starter? I would swap to a 4 brush if yours is 2.
- ccentralm
29 Aug 2010 10:06
we've found a new problem that i wanted to run past you guys. the headlight bulb has three prongs coming off of it and from what i understand, each prong is pulling 4.3v. is this right? is there an easy way to correct this if this is a problem. what things should be checked?
29 Aug 2010 10:25
ccentralm wrote:
Three wires to headlight are for bright, dim, and ground.
Each prong should be supplying full battery voltage to the particular bulb filament being lit.
- ccentralm
02 Sep 2010 15:12
so does that mean this is correct in 4.3v going to each prong and should need no correcting?
- MFolks
02 Sep 2010 16:13
I'll try to explain on the headlight bulb wiring:
One prong is the ground circuit(usually a BLACK with YELLOW wire)
Another prong is the high beam circuit(maybe BLACK with RED stripe).
The third prong is the low bean circuit(maybe RED with YELLOW stripe).
If you remove the headlight from the housing, the headlight bulb will have the socket plugged into it, carefully pull the socket straight out without twisting. Now you can check the voltage going to the headlight using a meter. The voltage will be the same on both high and low beam circuits, it's the bulb that makes the high and low beam brightness difference.
Last edit: 02 Sep 2010 18:35 by Patton.
Last edit: 02 Sep 2010 18:36 by Patton.
- ccentralm
10 Jan 2011 11:43
i'm going to give up on the dyna ignition and turn everything electrical back to stock. the only problem with this is the fact the stock wiring harness has been cut when the stock IC igniter was removed from the harness completely. heck, perhaps this is the route of all of the problems. anayways, i'm tired of all the new fangled hot rod crap and just want my old 750 back. i plan on going back to original coils and plug wires too. i see a few cheap wiring harnesses on ebay. does anyone know what models coincide with my 750H3 as far as electronics go? i would really appreciate this.
- Motor Head
10 Jan 2011 14:22
Before giving up and going away from the Dyna, maybe have a look at some threads.
kzrider.com/index.php?option=com_kunena&...ew&catid=4&id=388730
kzrider.com/index.php?option=com_kunena&...ew&catid=4&id=397011
Maybe post where you are as lots of guys here to help you, and your dad. You hadn't posted so I would think all the guy's thought you fixed or sold it.
That bike should handle the extra system draw from the Dyna Ignition.
- hocbj23
10 Jan 2011 17:02
ccentralm wrote:
Not sure why stock harness was cut.All that was needed was to unplug ignitor harness and wire Dyna into red wire (switched voltage).I have Dyna S and Dyna 3 ohm coils on my Kz and they function perfectly.bji'm going to give up on the dyna ignition and turn everything electrical back to stock. the only problem with this is the fact the stock wiring harness has been cut when the stock IC igniter was removed from the harness completely. heck, perhaps this is the route of all of the problems. anayways, i'm tired of all the new fangled hot rod crap and just want my old 750 back. i plan on going back to original coils and plug wires too. i see a few cheap wiring harnesses on ebay. does anyone know what models coincide with my 750H3 as far as electronics go? i would really appreciate this.
- ccentralm
11 Jan 2011 10:13
then this very well could be my problem. i failed to mention that not only is the harness chopped but one of the coils was blown too due to wiring mistake. i was having my dad do all the electrical, but i'm done throwing money at it having him experiment. i just want to return it to stock. does anyone know what 750 models use the same wiring harness as my 82 750 ltd? there's a few examples on ebay for an 80-83 750's, but i couldn't figure out how to cross reference a wiring harness.
