OEM Pickup Pulsing coil measurement.
- otakar
18 May 2010 12:28
I just got two sets of extra ignition pulsing coils on eBay. I wanted to check them to make sure they are good. According to the book they should measure between 360-540 Ohms. When i measured these they Ohm out at about 680. So I decided to go outside to check the ones on my bikes. They also Ohm out at 680. What gives??? Anyone here ever check theirs to see what they measure?
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- otakar
Re: OEM Pickup Pulsing coil measurement.
18 May 2010 12:50 - 18 May 2010 12:52
Never Mind. I'm a DORK. It would help if I was reading the right scale on the tester. It is analog and not digital. Now that i am reading the right scale they Ohm out at about 460. :blush: :huh: I guess I scored two sets of good pulsing coils for $18 a set. Not bad I guess.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Last edit: 18 May 2010 12:52 by otakar.
- MFolks
18 May 2010 12:59
Ohm Checking Pickup(Pulsing) Coils
The pickup coils on the Kawasaki’s with the factory supplied electronic ignition can sometimes fail or become intermittent due to heat and vibration.
1.Trace back from where the pick up coils are mounted,(under a right side CD sized cover) locate and disconnect a small 4 pin connector. Using a multi-meter set on OHMS and range of X 100 check between the BLUE and BLACK wires(#1 and #4 sparkplug wires) for between 360- 540 OHMS.
2.For #2 and #3 sparkplugs the wire colors will be YELLOW and RED, again 360-540 OHMS.
3.If the pickup coils are suspect of failing due to heat, they can be stressed using a hair dryer without the need of the engine running.
4.A replacement set of pickup coils might be obtained from a dealer who serviced the police Kawasaki’s.
5. If replacement pickup coils are not available, your next choice would be to order a Dyna “S†electronic ignition system from www.z1enterprises.com It replaces the IC igniter with a smaller module located where the mechanical ignition advancer was mounted.
6.Check the small 4 pin connector that the pickup coils connect to for corrosion/loose pins too.
- otakar
18 May 2010 13:08
I do know which leads to check. My problem was that I was reading the wrong scale on the Analog VOM. My coils are fine and I just bought two extra sets on eBay. Brand new coils are still available from Kawasaki. they are 59026-1133. They will work on all the earlier KZs 79 and up.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- MFolks
18 May 2010 13:19
I just had them priced at
www.kawasaki.org
(the website for Beartooth Kawasaki). OEM price is listed at $139.05 with membership it's down to $118.19
It's nice to see they are still available and could influence people to build Loudhvx's version of Kawasaki's IC Igniter system.
- TeK9iNe
- What did you do!?!
18 May 2010 13:50
otakar wrote:
Time for new "auto-ranging" Multimeter.
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- otakar
18 May 2010 14:02 - 18 May 2010 14:05
TeK9iNe wrote:
Believe it or not but for certain things i really like an analog scale. Especially the very low resistance measurements. I still have a very nice old meter that has a 3.5"x4.5" scale for when I want to use one. I love to use it for measuring all kinds of coils such as low impedance fuel injectors, Ignition coils and such. Hay, I might be a Dinosaur, but I'm a Tyrannosaurus Rex :lol:
otakar wrote:Never Mind. I'm a DORK. It would help if I was reading the right scale on the tester. It is analog and not digital. Now that i am reading the right scale they Ohm out at about 460. :blush: :huh: I guess I scored two sets of good pulsing coils for $18 a set. Not bad I guess.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Last edit: 18 May 2010 14:05 by otakar.
- otakar
18 May 2010 14:28 - 18 May 2010 14:32
MFolks wrote:
I am going to build a three pickup system for my KZ1300. I bought new Nology Mini Coils for it and I would like to try something a bit different. I have two extra ignition modules for it but I think that Loudhvx's module might be quite a bit better. The Nology coils are 2.4 Ohm but are designed for 3 Ohm Ignitions. Figure that out!
www.nology.com/profiremotor.html
I just had them priced at www.kawasaki.org (the website for Beartooth Kawasaki). OEM price is listed at $139.05 with membership it's down to $118.19
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Last edit: 18 May 2010 14:32 by otakar.
- loudhvx
18 May 2010 15:15 - 18 May 2010 15:17The key word there is "certain". Not all 3 ohm systems are the same. What determines the system's dwell requirements are the resistance and the inductance of the primary. It could be they adjusted the inductance on that coil (increased it) so it charges at a rate similar to the specific 3-ohm system they are referring to.
I use a 3-ohm coil on a system designed originally for a 2.3 ohm coil (though they usually measure about 2.4 to 2.7 after 30 years). I guess 2.4 and 3.0 are close enough that in some cases they can be swapped. But that may not be true in all cases.
Another thing to keep in mind is that sometimes a resistance is specified, but not because of the dwell characteristics, but because of what the output transistor can handle. I think the Dyna S is an example of that. But the proper way is to match the coil's current-saturation time to the system's dwell time (which varies with RPM, usually) to make it efficient and running cool while still getting the best spark.
BTW, very nice score on those pickups. This is not an easy time of year to get deals on parts. Good to see they're still out there.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
Last edit: 18 May 2010 15:17 by loudhvx.
- otakar
18 May 2010 16:14 - 18 May 2010 16:16
loudhvx wrote:
I'm a Baaaaaaad Boy. I just scored another one for $18. This time complete with thee Magnetic plate. :silly:
When I talked to Nology on the phone they recommend the coils on all the PRE 81 ignitions but not the "J" series 2.2 ohm ignitions. They do recommend them for the 1300 which is a 3 Ohm ignition. Do you think I will be OK with the GM modules on the Nology coils than? You can take a look at the PDF catalog and they make specific bike and year recommendations.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Last edit: 18 May 2010 16:16 by otakar.
- loudhvx
19 May 2010 08:00
I couldn't find a page on their site that had technical info. However, I did notice the Nology coils seem somewhat larger than the "mini-coils" I've seen from Dyna. The larger they are, the more they can handle extra dwell. Either way, the HEI provides less excess dwell at idle than the stock igniter so it should work fine if not better (for keeping the coils cool).
Here is what the Dyna mini coils look like. They must only be used on systems where the dwell is properly matched for them. Notice how small they appear.
1981 KZ550 D1 gpz.
Other links.
Other links.
- otakar
19 May 2010 08:33 - 19 May 2010 08:39
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Last edit: 19 May 2010 08:39 by otakar.
