Letter to Newtronic, timing, stammering, and COIL
  • loudhvx
  • loudhvx's Avatar
Re: My letter to Newtronic support - your thoughts?
07 Apr 2006 19:48
#37720
Intermittent coil problems are one of the hardest to troubleshoot without using the "replace it to test it" method, which can get expensive. Glad you got it solved!
  • Biquetoast
  • Biquetoast's Avatar Topic Author
  • King Jeremy The Wicked
08 Apr 2006 05:26
#37776
You ain't kidding!
And remember, I'm still really a newbie in a lot of ways - never really turned a wrench until I got my 400 3 years ago, so I'm still not that good at spotting the obvious sometimes.
...but what truly made the light go off (pun intended) in my head was: When I was setting the timing for the millionth time with the timing light, I suddenly realized that the light wasn't blinking perfectly steady. It seemed to miss one or two every once in a while, then it would miss every other one for a series of maybe ten or so. I tried the timing sensor on both plug wires and the result was the same (again, only when the coil warmed up a bit). Mind you, since the ignition was Newtronic, and the wires had been replaced, it really couldn't be anything else. I was so pissed at myself for never really *seeing* that before, even though I've probably seen it a hundred times.
Again, thanks to all you guys for all the advice and time spent on this problem.
EDIT: I think I'll rename this thread so it better reflects the outcome...
Post edited by: biquetoast, at: 2006/04/08 08:31
(1.) '75/'76 KZ400D - Sold
(4.) '75 KZ400D - Sold
kz750twins.com
  • loudhvx
  • loudhvx's Avatar
08 Apr 2006 07:17
#37805
Yes, the strobe timing light is good for a lot of things other than setting timing. It also exposes false triggers in an electronic ignition system. A false trigger will produce a "ghost image" of your rotor in the wrong position.
Post edited by: loudhvx, at: 2006/04/08 10:19
