points/timing help
- bobbisman
points/timing help
30 Apr 2010 12:28
i just installed green dyna coils and i am getting spark but i think my timing may be off or the points arent set correct. ive read to check the timing i can make a timing light with a light bulb using 2 wires and aligator clips. one clip to ground and the other to the spring inside the timing cover for the cylinders to be tested. once the "f mark is lined up for those particular cyclinders for instance 1&4 the light bulb should light up. the problem im having is ill have the timing light for cylinders 1&4 but it lights up when the "f" mark for cylinders 2 and 3 is alinged. can someone help me check and adjust my timing please
- bobbisman
Re: points/timing help
30 Apr 2010 12:35
should the points for the particular cyclinders be open when the corresponding f mark is lined up?
- Kawickrice
30 Apr 2010 12:35
Set the gap first to see if that helps
73 Kawasaki Z1
07 HD CVO Ultra Classic
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
79 RD 400 Daytona Special
72 Honda CL 175
74 Honda QA 50
Tampa FL
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
72 Honda CL 175
74 Honda QA 50
Tampa FL
- Kawickrice
30 Apr 2010 12:38
Dont get ahead of yourself. After the gap is set then you can get the light to fire on the "F" mark. Set1-4 first then set the 2-3 that should get it to run so you can use a strobe timing light.
73 Kawasaki Z1
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
72 Honda CL 175
74 Honda QA 50
Tampa FL
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
72 Honda CL 175
74 Honda QA 50
Tampa FL
- bobbisman
30 Apr 2010 13:01
gap has been set. when fully open the gap is no more than .016.
- Kawickrice
30 Apr 2010 13:07 - 30 Apr 2010 13:09
What kinda bike you working on? On the 900/1000 .016 is on the high side but still within spec.
73 Kawasaki Z1
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
72 Honda CL 175
74 Honda QA 50
Tampa FL
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
72 Honda CL 175
74 Honda QA 50
Tampa FL
Last edit: 30 Apr 2010 13:09 by Kawickrice.
- bobbisman
30 Apr 2010 13:47
78 kz 650b. i justed adjusted to the lowest tlerance being .012. i think it may be a fuel issue. i tried turning the engine over with the throttle wide open hoping this would cause the plugs to get wet but there bone dry. im stumped
- TeK9iNe
- What did you do!?!
30 Apr 2010 15:29 - 30 Apr 2010 15:32
bobbisman wrote:
With the throttle wide open, your just blowing off the plugs.
If you want them to get wet, put the choke on full, and dont open the throttle. They'll get plenty wet! :laugh:
Timing points can be a huge pain. Make sure that the points themselves are perfectly flat and clean, very clean.
This is a very good source of info on points timing/setup: HERE
When trying to start the bike, DONT touch the throttle. It defeats the choke system, and makes it harder to start. Only play with the idle screw if necessary.
GL!
GL!
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
Last edit: 30 Apr 2010 15:32 by TeK9iNe.
30 Apr 2010 18:31 - 30 Apr 2010 18:33
When viewing points: set at 9 o'clock should begin opening when F mark for 1/4 aligns with case timing mark; and set at 3 o'clock should begin opening when F mark for 2/3 aligns with case timing mark.
With opposite results, points cam is probably installed 180 degrees out.
Last edit: 30 Apr 2010 18:33 by Patton.
- bobbisman
01 May 2010 11:12
Patton wrote:
if the points cam is installed 180 degrees out, how is this fixed. the thing that confuses me is the bike was running at one point but stopped getting spark. its getting spark now with the new coils installed but wont start
- bobbisman
01 May 2010 11:56
it does appear the points cam is off 180 degrees. when i line up the f mark for cylinders 1&4 and then slowly turn the engine over the points for 2&3 start to open. i just dont understand how its off 180 degrees now since it was running when i last put the bike up
- Kawickrice
01 May 2010 11:59 - 01 May 2010 12:00
Can you take some close up picks? Did you even mess with the lobe or remove it for any reason?
Do you have a test light?
73 Kawasaki Z1
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
72 Honda CL 175
74 Honda QA 50
Tampa FL
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
72 Honda CL 175
74 Honda QA 50
Tampa FL
Last edit: 01 May 2010 12:00 by Kawickrice.
