Major Help Needed
- nwoods29379
- MFolks
- Thank you received: 540
kz750twins.com/
- loudhvx
- Thank you received: 1616
Can you see the points? It's the small cover on the right side of the motor. Are there points under the cover or is it an electronic ignition?
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
- nwoods29379
Looked up ignitions on ebay lol... it is the stock points ignition.
- loudhvx
This is just so you can check the engine. I can make a more complete one later if you are planning to rewire the bike. If not, then you can use the factory wiring diagram found in the filebase.
Don't leave the power on for very long without running the motor. It can overheat the coil.
1981 KZ550 D1 gpz.
Other links.
- nwoods29379
- MFolks
www.easternbeaver.com
www.vintageconnections.com
www.electricalconnection.com
www.electricalconnection.com/electrical-components/hitachi.htm
- nwoods29379
- MFolks
www.nrp-carbs.com
www.motorcyclecarbs.com
www.carbparts.com
www.carbkitscapital.com
www.pjmotorsports.com
www.jetsrus.com
www.sportingforless.com/servlet/the-Carb-repair-kit/Categories
www.cycleorings.com/
And go to www,babbitsonline.com for a diagram of you carbs.
- nwoods29379
- MFolks
The 750 twin is probably similar(could be wrong).
- nwoods29379
then going up into the headlight housing.
This is where I'm having issues since I have nothing on the front end to use as a reference. The frame is bare except for the engine and now electrical plate.
