Ignition circuit diagram?
- 2006hhr
- loudhvx
- Thank you received: 1616
If 12v on both sides of both coils, then Dyna S is not doing its job.
If 12v on both sides of 1 coil and not the other, rotate the engine slightly. At some point, both coils should have 12v on one side and near 0 on the other.
If you can't get both coils to 12v on one side and 0 on the other, the Dyna has failed, or it has a bad ground. It grounds thorugh the engine so make sure the engine ground is in good condition.
It can also be that the wires from the coils to the Dyna S have failed, or the Dyna S doesn't have power on it. Check all of that.
If you used the little blue press-on connectors that tap into wires, they are usually faulty. Do proper splices with solder or crimp connectors.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
- 2006hhr
- loudhvx
1981 KZ550 D1 gpz.
Other links.
- loudhvx
The Dyna uses the engine for ground. Are you sure the engine is grounded... ie. do you use the starter, or are you kicking it?The dyna has power to all the wires and up to the coils, just no power out, i even grabbed the plug while cranking, no shock at all.
Also, it's likely the reg/rec failed or lost regulation and caused the Dyna S to fry. (Based on your blown light bulbs.)If the Dyna S is dead, the first thing to do when it's replaced/fixed is to verify the battery voltage doesn't go above 14.5v when revving.
1981 KZ550 D1 gpz.
Other links.
- 2006hhr
- Jonny
- woot!
- Thank you received: 22
Check the fuses?
Have a volt meter to measure for battery voltage throughout the wiring diagram (on the coils)?
All I have is the B3, C3 wiring diagram.... Maybe it will help....
Any chance you could post that awesome color wire diagram in a downloadable format? I can't seem to pull it down off the website... Everything I have is in black and white. = a royal pain to trace everything with your fingernail and hope you don't miss a turn.
Factory manual wiring diagrams are a little like playing one of those maze books for kids, only assuming they made them in hell. While your KZ sits dead. :S
Jonny
'78 KZ 650C2 'Lila'
'71 Norton Commando 750 'Eadie'
St. Catharines, ON (Mostly, anyway...)
- 2006hhr
- rstnick
- Thank you received: 378
diagrams.kz650.info/index.php
Rob
CANADA
1978 KZ650 C2, 130K kms, Delkevic ex, EI, CVK32, PMC easy clutch, ATK fork brace, steering damper, Progressive Suspension, braced swingarm, ZRX shocks, 18" Z1R front wheel.
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
- 2006hhr
