78 fram 82 motor no juice
  • Eldiablo
  • Topic Author
  • 1978 kz650 with 81 750 motor
08 Sep 2009 18:56 - 08 Sep 2009 18:57 #320020 by Eldiablo
78 fram 82 motor no juice was created by Eldiablo
i just picked up a 78 kz650 that has a 82 750 motor mounted to it.
problem is it wont get juice no where. all the wiring seems to be in the right spots but nothing. not even a headlight flicker.
i know there is a 2 diff regulator/ret for the two diff years.
the one on it now is a 3 wire plug with a red and white wire by its self.
is this the proper r/r?
thanks for the insight
1978 kz650 with 81kz750 motor, dyna coils/pickup, 4/1 header, d&d pipe, pods, gsxr brake controls, airtech clipons, r1 taillight, and cafed out
Last edit: 08 Sep 2009 18:57 by Eldiablo.
  • Kawickrice
08 Sep 2009 19:33 #320034 by Kawickrice
Replied by Kawickrice on topic 78 fram 82 motor no juice
Did ya check your fuses? Is the battery charged?
73 Kawasaki Z1
07 HD CVO Ultra Classic
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
79 RD 400 Daytona Special
72 Honda CL 175
74 Honda QA 50
Tampa FL
  • Eldiablo
  • Topic Author
08 Sep 2009 19:51 #320037 by Eldiablo
Replied by Eldiablo on topic 78 fram 82 motor no juice
Yup all fuses are good and the battery is charged. I even put my snap on jump starter on it for extra juice.
08 Sep 2009 20:27 #320048 by kzr750r1
Replied by kzr750r1 on topic 78 fram 82 motor no juice
Are you using the 650 wireing harness or the 750?
I'm assuming the latter. I can go look at my 750 manual in a min and see what rectifier leads should be.
Not going to be able to help on the 650 side what it needs. I don't have one.
KZ750R1 + 1991 ZR750 = KZR750R1
Better to be shot out of a cannon then squeezed through a tube. - HST
  • Eldiablo
  • Topic Author
08 Sep 2009 20:51 #320052 by Eldiablo
dont know the swap was done before i bought it.
08 Sep 2009 21:08 #320060 by PLUMMEN
Replied by PLUMMEN on topic 78 fram 82 motor no juice
get your meter out and start at the battery checking for power as you go B)
  • Eldiablo
  • Topic Author
08 Sep 2009 21:28 #320066 by Eldiablo
Ok found a blown fuse. Small opening almost Missed it. Thing is this bike has a modded harness. So what the fuse goes to I have no idea. I will track it down.
Can some one post or tell me where I can find a online diagram for a 82 750
08 Sep 2009 21:54 #320071 by Patton
Replied by Patton on topic 78 fram 82 motor no juice
In the green ribbon toward top of screen, "point" to KZ Information and then click on Filebase.
Next, find and click on 1982.
Or just click here >> Above navigates to this screen
Click on particular model of interest.
Watch for a wiring diagram to unload.
Good Luck! :)
  • Eldiablo
  • Topic Author
08 Sep 2009 22:04 #320073 by Eldiablo
Ok looking at the diagrams I noticed that it has the 78 r/r on it. Now I need to find out if it has had the the 78 alt put in it
  • Eldiablo
  • Topic Author
08 Sep 2009 22:16 #320075 by Eldiablo
Just looked at the wireing. It has the black wife coming off the ground to the batt and red and white going to the batt. And the. The 2 leads to the stator. So thats correct. More wiring fun tomorrow.
09 Sep 2009 05:15 #320103 by Patton
Eldiablo wrote:
...has the black...coming off the ground to the batt....
May also notice the black wire changes to black/yellow as ground to battery negative.
Good Luck! :)
  • Eldiablo
  • Topic Author
09 Sep 2009 18:11 #320271 by Eldiablo
ok got everything running. it was just + grounded to the frame.
one thing
the wires to and the r/r get really hot i am pretty sure she is out.
